NoGasNoGo
- Keokuk, Iowa
- 2015 GTI
What’s the Specific dics that you installed sprung like in the pic?Here is the clutch, I don't have a picture of it. I was thinking I might need to measure that, but didn't know what the specifications are to compare it to.
If the disc you have is sprung with those large springs that’s your problem... and fcp listed the kit wrong.It's my daily driver and I wanted to stick with the DMF to keep it quiet and comfortable as well as a sprung center disc. Iam installing an IE stage 1 tune, so needed a little more holding power, but didn't want anything too aggressive, heavy, and loud. This seemed to fit the bill.
not to doubt you... but i do lol.The sprung center sticks out more on the presure plate side and clears everything. I already took it all back apart once to check it all. If that disc is put in backwards you are correct, it won't clear, but mine is in correctly.
keep in mind the gap between the fingers and the PP shrinks alot as you tighten down the PP bolts to spec, so when you "test" fit it there is much more clearance.The sprung center sticks out more on the presure plate side and clears everything. I already took it all back apart once to check it all. If that disc is put in backwards you are correct, it won't clear, but mine is in correctly.
You say that to all the boys.I hope for the best for you, but I think this will slip.
Did you ever see that old Eddie Murphy movie - come to America, I think it's called. There's a scene there where he goes "when you think of garbage think of Hakeem".You say that to all the boys.
