GTI Jake
- Charlotte, NC
Dealers owing smoke. Try rocking the car back and forth and see if you can get into first. With a bad clutch or hydraulics you can't always just slide it into gear without a little movement
I'm being a hydraulic cylinder or line broke. If you merely had a bent diaphragm finger the pedal would still work even though you wouldn't be able to get it into gear.
T.
I wasn't suggesting one bent finger, rather the ring that spring loads all of the fingers. Had the same problem on a friends mk6
