SnailPower
- North NJ
- 2017 GTI MT, PP, LP
Damn, sorry you're still chasing this thing. The hatch bump stops are adjustable - there's a small Allen head in the center of the bump stop that you loosen, then you can slide the stop in our out as needed before tightening the Allen back down.
I think it was mentioned above, but did you double check and/or replace your sway bar end links?
One other thing I can think of - I believe some lowering springs have sleeves on the coils to prevent rubbing/contact. Is it possible this could be your issue? See these: https://www.ecstuning.com/b-034moto...YQeot_VUIig3T3d1Mzge6W9CNVlzXl2hoC8MMQAvD_BwE
Did not replace the rear bar endlinks with the install. Everything was OEM minus what was included with this kit, https://www.ecstuning.com/b-ecs-par...bfeRZDucRjyDqznDlf2BOaLHbCIohe0xoCWU0QAvD_BwE
The lowering springs did not have sleeves from what I could recall.
EDIT- I'm going to give the bump stops an adjustment tonight. Thank you.
