Clubsport S Suspension
Hdoherty
uk
gti golf
Hi All
New to the forum , has anyone fitted suspension upgrades to the Clubsport S. Any comments/feedback would be appreciated.
GolfRRRR1
Michigan
I've bought the Clubsport S front knuckles for my '16 R (hoping to achieve an extra 1* neg camber without any noise). Adding more grip to the front is always a good idea. I just haven't installed them yet.
Both front knuckles were $407us from e-acca.
5Q0407254E
5Q0407253E
Welcome to the forum.
Awdacty
Manitoba
5Q0407254E
5Q0407253E
Is an extra degree what they're supposed to give you? I'm thinking about doing that rather than fixed camber plates.
The Dude
PNW
another option would be the Verkline LCA's, which are adjustable, or the Superpro arms which don't increase negative camber as much, but they increase caster, which adds dynamic camber.
odessa.filez
Tampa, FL metro
another lca option is ttrs front control arms which can get you to over 2.25 degrees or more. Wider track too
GolfRRRR1
Michigan
Yes, so say your car has -1* camber as it sits, after install it will have -2* camber, all factory, all quiet. If you want more then you can add other parts, just like you would with the stock parts...you're just starting from more negative camber already.
More and more options are popping up, I just chose this one over the modified upper strut mounts which give some people issues/noise.
Good luck.
