No worries. No one was talking about errors (or lack thereof) with your retrofitBro I'm French, sometimes the translation in my language is not good, so don't blame me
Perfect ... Thank you very much for the tips. Just one more question: can you tell which functions are working and which are not working with the new digital climatronic panel in relation to the ac manual?Yes, I'm referring to errors when swapping a Climatic panel with Climatronic.
Dual zone won't work and auto mode is a bit dodgy, but temperature regulation on Sync mode works well.Perfect ... Thank you very much for the tips. Just one more question: can you tell which functions are working and which are not working with the new digital climatronic panel in relation to the ac manual?
Got it. What about the temperature, it starts to be controlled according to the digital display?Dual zone won't work and auto mode is a bit dodgy, but temperature regulation on Sync mode works well.
Yes, that's what I meant by temperature regulation.Got it. What about the temperature, it starts to be controlled according to the digital display?
This new display looks nice, I know it's offered in the new 2021 Arteon. I don't speak French, so I didn't under stand, were you saying this was a direct replacement or was there coding that needed to be done in ODIS, I already have an Automatic Climatronic system in my Golf R, but this would be a nice upgrade to the cockpit. Car is only heated seats.
Hi, I've swapped this touch panel into my golf with oem climatronic, but as you said the Clean Air button worked only when I installed it, the nex day was dead. When I press this button no lights went on and also on the menu screen of the clima, I can't no more activate the Clean Air, I Touch the button on screen, it "sounds with the classic click" bit nothing happens. Could you please try to activate clean air via your clima menu? So I can compare with my situation.So, I just installed this unit into a 16 Golf R, replacing the three knob Auto Climatronic systems interface. I have a quick question, everything is working like it should, it was a quick swap, prior to the installation, I was left with the impression that the "Clean Air" button would not do anything, but mine is, you can hear some flaps opening and "hear" fan speed change. I have yet to run a scan on the system in both modes, so I thought I would ping everyone on here, as to any info on what it might be controlling?
I have activated via the menu, I get the same effect, I hear a click (like a internal vent flap is being moved), then I hear a fan speed change. I hope this helpsHi, I've swapped this touch panel into my golf with oem climatronic, but as you said the Clean Air button worked only when I installed it, the nex day was dead. When I press this button no lights went on and also on the menu screen of the clima, I can't no more activate the Clean Air, I Touch the button on screen, it "sounds with the classic click" bit nothing happens. Could you please try to activate clean air via your clima menu? So I can compare with my situation.
All the others functions are OK, and all the adaptations were done right, and I also can hear the vent with more power when I press that button.
Thank you and sorry for my English.
HI vwlotech, today I have solved this problem. I tried to do basic setting for 5 times without any lucky from the panel, and 3 times from obdeleven always without lucky, so I have switched to the old panel, and done a basic setting(the error about the basic setting was gone), then I reinstalled the touch panel and performed a new basic setting, this time with lucky, the error is gone and now I can activate the Clean Air from this touch panel (the dedicated button lights up) and from the menu as always. I hope this can help you.I have activated via the menu, I get the same effect, I hear a click (like a internal vent flap is being moved), then I hear a fan speed change. I hope this helps
KEVIN did you code it ?, I bought it and I cant make it turn the ac compressor on . I have obdeleven pro GOLF R 19Tactile? This is the opposite of the definition of the word.
RLACOSTA69KEVIN did you code it ?, I bought it and I cant make it turn the ac compressor on . I have obdeleven pro GOLF R 19
