Class action lawsuit letter (Waterpump)
kyLman
Grand Rapids, Michigan
2015 Golf
Welp, the waterpump housing finally let go... and now im leaking like a sieve instead of the slow leak like it was for the last year and a half.. I called one independent shop... 1100$
2015 VW Golf @ 94k miles, also passed the class action
tigeo
8 year old car, at this point, some repairs are to be expected.
ElectricEye
Central NJ
Does that $1,100 include parts?
tigeo
I paid a bit over that for genuine OE VW parts and labor at my indy shop. That work is warrantied for 3 years/36K parts and labor. VW reimbursed me $1150 for the job so that seems to be about right/book rate for it.
ElectricEye
Central NJ
That's fantastic.
I paid way too much at my local indy shop.
I knew it was too much, as I'm aware of the general cost of these replacements from being on this site for so long.
But the car was there, and I wasn't going to tow it out.
I'm past the waterpump reimbursment time frame/mileage ratio as well.
I still love this car, but plan to get out of it in about two years.
tigeo
That's fantastic.
What did they charge you?
ElectricEye
Central NJ
I'm embarrassed to tell you, but it was north of $1,500.
JA Autowerks in Redbank NJ.
They're very good, they know what they're doing - but they're pricey.
I would have been better off at the dealership.
They did two other relatively recent repairs on the car, and they were far more $$$ than they should have been.
I'm not going back there.
It sucks, because you try to be smart... Try to do your research and find a good indy place that specializes in VW's, Porches, and Audis and this happens.
tigeo
It happens.
ElectricEye
Central NJ
It happens.
Yeah, if I could have driven it somewhere else (I had it towed there) I would have, but it was there so I said "Do it."
At least it's done now.
I've been waiting for this failure forever.
tigeo
Prices vary. Folks always jump in these threads with "I paid $200". Any reputable shop using OE parts that makes money is going be close to the alldata rate....some a bit higher some a bit lower.
PerceivedShift
Mine is still holding out at 98k miles. Figure I'll replace it when I install MPI eventually. Brother's Sportwagon's waterpump took a dump just in time at 75k and got it replaced under warranty.
Last work I had done at an indy, they called with a crazy high price for the work, I pushed back, and they said it was because they had to remove the subframe to do the work. I reminded them that you only need to remove subframe for DSG and they brought the estimate way down.
Don't be afraid to call BS and push back.
kyLman
2015 Golf
i'm thinking of coupling this water pump service with walnut blasting the intakes, but I only have the baby 1.8 stock. Has it been in other's experience, to still get the intake cleaning service?
they quoted me 2k in total
Tom1759
Delaware
Mk7 Golf R
7 months after getting my water pump replaced under the warranty and my low coolant light came on today. I had checked it a month or so ago when I did an oil change and it was full... anyone else had a similar issue?
I need to call the dealer tomorrow but hopefully the new pump came with some kind of warranty.
uberdot
Ten Forward
Silver 2017 6MT
The gauge on my dashboard is not aligning with actual coolant temps and showing comically high readings on the dash than it is through OBDeleven. Coolant temps are within 197-220 via the app.
I'm getting Engine Coolant Bypass Valve Control code P268100 and Engine Coolant Flow/Low Performance code P00B700. For those that got approved for extended warranty, were these issues present before bringing it in? I have an appointment Friday, the car meets the criteria for the settlement. Just wondering what to expect and if it's even water pump related. I am slowly losing coolant, FWIW
