Little update on the clutch:
As I posted on one of the DKM threads, I had some concerns as I was feeling the clutch pedal vibrate/grind on higher RPM downshifts. I can actually replicate it just by free-revving in neutral and you can hear it at 3k~ RPM.
I now have 1300~ miles on the clutch and that grind is still present, but it isn't as strong/loud like before. After talking with the mechanic and Clifton over at DKM, I guess it's 'normal'. They said it could be a combination of SMFW and the stiffer engine/trans/dogbone inserts.
Guess I'm ok with it for now, as I'm not having any other issues with getting into gear, downshifts, any other abnormalities. Chatter/gear lash is pretty loud when it's hot outside + AC on but this seems to be normal across most SMFW clutches. The hotter the weather, the louder it seems to be at idle. Not too big of an issue for me as I have music playing most of the time. Sometimes take-off is a bit jerky after starting/stopping in heavy traffic but that's likely normal too with SMFW, and is all dependent on how I modulate the clutch and how much throttle I give it.
This is my first ride with an aftermarket SMFW clutch so this might just be normal to everyone else
