Showing 'no symptoms' does not mean your valves have no carbon build up. I promise you they do, just as the valves on my car do, even after manually scrubbing them twice. I've cleaned valves on about six Mk5/6 engines, including my own. Some of the cars not showing symptoms had worse buildup then those with symptoms. The effect is blocking air flow and causing air turbulence. This may or may not cause a rough idle or starting hesitation, but it will doubtlessly reduce air flow and create turbulence to the air charge, causing a less efficient combustion and reducing power, even if one does not "feel" anything.My mk6 at 75k miles was showing no symptoms of carbon of build up.
It's easy, but it takes time because the valves need to be soaked in chemical cleaner for a long time before scrubbing them. Some of the build up is gooey and some of it is rock hard. I pour B12 Chemtool in the intake ports and forget about it for a few hours while they soak. There will always be at least one cylinder with the valves open, so you can only do up to 3 cylinders at a time, then you have to rotate the crank to do the final 4th cylinder. From a cost standpoint, it's a cheap process. Some zip ties, bore/pipe cleaners, few bottle of B12. You'll also want to buy a hook/pick set (like pic below) to clean at the top area of the valve stem where it goes into the valve guide. I'd recommend giving yourself the weekend if you have never removed the intake manifold before. Also, if you plan to work on ANY Volkswagen, make it easy on yourself by picking up a Bentley manual for the car in electronic or hard copy.How hard is it to do yourself? I know it depends on your mechanical ability and such. But for an average guy that has some logic.
Walnut shell blasting is a very good option. What is important is that people understand there must be at least some kind of abrasive action to clean the valves, whether scrubbing or blasting. A chemical spray alone (SeaFoam, BG Cleaning) will NOT be enough. Even cars that are running methanol injection all the time still have carbon build up - there are photos on GolfMkV.com proving this on a VW engine that always runs meth.Overall the cleaning of the cars are a must. I do not recommend a scrubbing and if you have to apply carb cleaner with caution ensuring the valves are closed completely. If the chemical gets past the valves and runs down the cylinder wall it can wash away carbon that has formed and go past the rings. This gap similar to a rain drop running down a window may result in oil consumption or in worse cases lost compression. Audi used this technique on the RS4's locally to me soaking the valves overnight resulting in two motors having to be replaced.
The US is full of BMW guys that do walnut shell blasting at reasonable prices. This give you the best result and I am sure they would look at doing VW's.
Unfortunately, most people do not have the option of doing walnut shell blasting in their home garage as a DIY project. I too used to clean valves as a business for years (even had people drive to me from a different state) and have cleaned all cars using carb cleaner and scrubbing method. I no longer work on any cars besides my personal vehicles. I disagree that scrubbing the valves is bad or harmful to the engine in any way, as I have done this over and over to cars with no issues, including several times to my personal car with 184,000 miles now. One of the cars I cleaned drove over 230,000 miles (370,000 kilometers) before the owner sold it to get a new Golf R. Of course I did not let valves soak overnight, like the dealership you speak of, and I certainly did not attempt to clean a cylinder when the valves were open. Almost everyone cleaning the valves is using carb cleaner and scrubbing. You are the first I have heard suggest that it is harmful, and I'm skeptical to say the least given you have a financial incentive to suggest a different method. I know scrubbing is an effective method to clean the valves, and all evidence I have come across supports it being safe. Maybe the Audi dealership did replace two engines, but dealerships replace engines all the time for many different reasons. This is actually more common on the Audi 4.2L V8 than any other VAG engine I know of. Perhaps the tech tried to rush by cleaning the cylinder with the valves slightly open on one cylinder. Or perhaps it was a completely unrelated cause.
I'll continue cleaning my valves with B12 Chemtool and scrubbing because I've found it to be extremely effective and inexpensive. The only downside I have found is the amount of time it takes.
Wow! That is very cheap. Thank you so much for posting! For that price I'll absolute be testing this method out when I do my next cleaning.There are cheap walnut blast tools available from in the US and its something for a enthusiast to look into. On the BMW forums they actually share the tools and even hire them out. Here is a tool that is very inexpensive http://www.harborfreight.com/portable-abrasive-blaster-kit-37025.html
and the shell you need http://www.harborfreight.com/25-lbs-fine-grade-walnut-shell-blast-media-92155.html
Yeah, I had good luck getting the back side of the valve stems and at the top of the stems by the valve guides by using the hook and pick set in this area more than others. These parts valve stem and guide parts are also submerged in fluid when letting the valves soak, so that makes things much easier.When doing the clean with brushes its virtually impossible to get around the rim of the valve or in some cases the back. The rim in turn causes a negative venturi, you can open the valve after the clean and see and its best to remove it if you have a pick as pictured further up.
Believe it or not, the actual Audi-approved method direct from Audi is to use a wad of 35 zip ties bunch in a group and held together by a rubber band or another zip tie in the middle, with the help of soaking the valves in cleaner. Yes, it's a little comical but this was described in an official report sent by Audi to its dealerships.
Wow.
BMW has the real mcoy. http://www.minitechinfo.com/tsb/attachments/M040311_Carbon_Blaster_Operating_Manual.pdf . I use this product, the N54 metal shoot also fits the TFSI/TSI port openings. There are some guys on N54tech.com that have made inexpensive ones too.
