JWadle
- Boulder CO
Does anyone know of a downpipe for the Mk7.5 GTI that includes a CARB-certified cat? As of 2021, Colorado requires this for all non-OEM cat replacements.
I don’t. I’m also in Colorado. Essentially you’ll need a cat with a carb and epa stamp. And it’s gotta keep your smog low while your tune has to make sure none of the emissions stuff has been deactivated and finally all of your emissions readiness must be set.
gluck. There’s a carb legal downpipe for the wrx. But the tune needed to run it deactivates a sensor. So your readiness is screwed. So as u can see, not a good option if you have to pass smog.
R downpipe won't fit.Best bet would be to swap to a R DP. Don't believe any aftermarket DPs carry CARB at this time. I'm in California, so I feel your pain. Though we just do Visual and ODBII now, so maybe a No CEL style might squeak you through depending on inspection.
With my 2009 sti, they whipped out the mirrors on a stick and checked EVERYTHING under the car. And they spend 15 minutes looking at everything under the hoodNo you don't. Besides the fact that you don't need to go thru smog here until your car is 7 years old. Then for the next 5 years they just OBD2 scan it. They could care less about what cat you have on the car as long as the monitors read set.
I ran my 996 Turbo thru smog earlier this summer with a super loud exhaust with 200 cell cats and they didn't even blink.
same with my fox body mustang. Same with my rx8. Etc
my point is, there’s discrimination here. If the car looks fun. Or fast. You’ll get picked apart. My rx8 had to go through air care’s ref’s because the exhaust was too loud. But it’s exhaust was stock
even if you don’t have to get emissions done for 6 or 7 years it isn’t worth it. You can be pulled over and asked to go to air care ref any time.
I’m in Aurora. When I was sent to the ref it was a castle rock cop. I did the yes sir no sir and I have disabled veteran Purple Heart plates on all my cars. I am always respectful when pulled over. I also don’t drive like a dick. I’m 38, don’t look threatening and my crazy driving is only at high plains track.All those cars are older than 7 years from new. Your current car isn't, in fact I don't have to take my car thru smog until 2026 here. I've *never* been harassed here by a cop for any modifications on my car. That includes my race cars that had roll cages, race vinyl etc.
If you drive like a jerk and are a jerk to the cop, they're going to respond in kind.
The Suby's get a bad rap here and I'm sure the Smog guys see plenty of whack stuff on most of the Suby's that come thru, so they get special attention.
My R has an IE open intake and an APR catted downpipe, I'm not worried about smogging it in 6 years when the time comes...
Let’s say you got pulled over because your car is too loud. The cop can give you a fix it ticket. You’ll have to present yourself at the emissions testing place. It’s called air care. For the ref you need an appointment. The ref picks through your car. Marking down modifications etc. they even look at the ecu too and they can tell if you’re currently on the stock tune tooWhat is air care ref?
From what I’ve gathered. Yes. Good ol carb hooks them up with tons of info on what a stock downpipe and exhaust look like. What bin numbers should show up on stock ecu etc. auto manufacturers have been forced to send this type of info to carb for almost a decade now.So they have equipment to read every brand of ECU that's available?
