I have a 1.8 TSI manual hatchback pre-facelift. After driving it for a month or so, there are clear issues with the engine. Most of the time the car doesn't pull like it should. I have driven other cars with the same 1.8 engine and they have an even strong pull through the rev range, from 2500 to 6000 rpm. Mine generally is weaker than that and is very inconsistent. Sometimes it pulls really hard, but that's rare and usually only in 3rd or 4th. Most of the time it pulls weaker than an 1.4, I have not been able to get to 100kph faster than 8.3 s, usually around 9 s or more. Some other times it starts weak and gets stronger after 3500 rpm, that's also rare. The only engine related error is the one here. Another issue I have is terrible fuel economy, around 15-16 L / 100 km in the city without flooring it. When cruising in second around 2200 rpm I see a steady 11-12 L/100.
I have made some logs with VAG-COM today and will do some more tommorrow. In the logs the pedal is down to the floor starting around 2200-2500 rpm. They are made in 3rd gear. Note that logs 05 and 06 have 2 different parameters from the first four, which I thought were also important. I would appreciate any opinions about these logs.
Regarding the logs, the guy with the vag-com said the sample rate is about 1/second, apparently that could be a lot better. He also said he can only record 12 parameters at a time, which seems to be a vag-com limitation. The parameters logged so far are in post #7 below. If you can recommend any changes for tommorrow when I make fresh logs, different parameters or anything else regarding procedure, I would appreciate that too.
