GLoBaLReBeL
- South Bend, IN
This is a rough guide to help anyone who is unable to open their hood on a MK7 Golf GTI/R. If you forgot to reconnect the hood latch cable, or it broke or for WHATEVER reason, this should get it back open for you. However. . . it isn't fun.
Things to know...
1. You WILL have to buy a replacement grill if you are unable to get enough clearance between the emblem hump and the hood cutout.
2. You WILL curse yourself for making such a stupid mistake after you have opened your hood.
3. You need to be CAREFUL when doing this, as you can easily pierce the AC condenser with the tools required.
Tools you will need...
1. 10mm box end wrench at least 6 inches long. The longer the better folks
2. Dremel with a plastic cutting wheel
3. Plstic/Metal hand held hacksaw. Something like this.. (It needs to be as this as possible, since we are working in a tight spot)
4. Painters tape and towels to cover your hood and bumper from buring hot pieces of plastic during your dremmeling.
5. A telescoping magnet to grab the bolts after they fall down and into the bottom of the front bumper. Seriously worth grabbing one from Harbor Freight for like $3!
Ok . . Lets do this!
What we are trying to do is get access to the 2 10mm bolts that hold the hood latch to the hood itself.
Hood Latch
First try and see if you can do this with a long 10mm wrench and pushing up on the hood itself to get access to the latch. You will do this by going through the gap between the top of the VW emblem and the hood notch above it. If you are unable to do this, please continue on and be ready to start cutting.
Cutting her up . .
Ok so you can't get to the hood latch bolt with an extended wrench. :-( Well, no fear, because its time to start cutting away and releasing some of that frustration on your grill. BE CAREFUL when doing this steps as you can damage your paint and the AC condenser if you are not paying attention.
Steps...
1. Tape off from the bottom of the hood up about 12 inches (or more) with towels and painters tape. This is to keep those burning hot plastic bits flying off your dremel OFF YOUR PAINT. Do the same for the front of your bumper.
2. Now pop off your VW emblem. Simply get a flat head screw driver (the thinner the better) and put it between the chrome plastic and the grill face and pop it off. You should start at the bottom right or left, pop it a little, then goto the opposite side and pop it again. Work your way up and soon it will just come right off. SAVE BOTH THE CHROME PIECE AND THE BLACK PIECE BEHIND IT!!
2. You will want to cut about a 6" wide hole/square out of the top of your grill. To do this, I cut out the center of the grill using the dremel. I cut out a box that took up most of the center and then did small circular cuts to make a circular hole. You do not need to do this yourself, but I did it to see if anything could be done to the hood latch mechanism to make this easier . . . NOPE. Then, use your hand hacksaw to cut further back to remove those humps in the back to get more access to the bolts. BE CAREFUL NOT TO PUNCTURE YOUR AC CONDENSER!
Here's what my grill looked like after I cut it up. You want to get enough room up top to reach the hoot latch bolts with your wrench.
Here's what it looked like with the hood still down, but looking at the hood latch bolts you need to reach . . .
Here's a better picture showing the bolts you need to get too...
Now here's what I would recommend you cut out to make this process easier on your hands and your sanity. You don't need to cut it ALL out, but the red rectangle is what I would cut out, and the red circle is just showing what I did cut out. Basically, you need that bump up top to come out and the plastic all leading back to the latch to come out as well. You can't salvage the grill after you cut out this stuff, so go crazy if you want BUT BE MINDFUL of your paint and the AC condenser behind the grill!!
Once you cut out that fun stuff you should see something like this . . .
At this point its time to get out a flashlight and see if you can reach BOTH bolts before continuing. Do not just start up on one bolt, and then the other. You NEED to be able to reach both, so check first and then start. If you can't get to them both, then cut some more out and check again. (This is why I would have cut out more than I did on mine. I had a hard time and it was getting late.)
Now I had to use the open end of the wrench and do short little turns for about 20 minutes on each side. If you cut out more than I did, you should be able to do much more and take much less time.
Once that is done, your hood will open right up Scream for joy and fix whatever was broken that wasn't letting you open your hood in the first place. Install replacement grill and have a drink of your choice!
Side Note: I installed a grill from PartsGeek that was about $60. It fit right in and looked fine. The honeycomb on this grill is not as shiny as the OEM grill, and the red line does not line up with the headlights, but other then that it fit perfectly. I blacked out my emblem and red line/chrome strip anyway, so you don't even notice. But, if you are anal about that stuff, go ahead and pay 199 for a new grill or take this chance to buy an aftermarket grill that fits your needs.
I hope this helped those of you that made the mistake I did or who just couldn't get their hood open for whatever reason. I have read soo much on here that I am happy to have been able to support the forum and give back!
Happy Wrenching!!
Things to know...
Hood Latch
Cutting her up . .
Steps...
Happy Wrenching!!
