Can't Change Settings While in Motion
Baldilocks73
Delaware, U.S.A.
2015 Golf R
I was using a loaner from the dealer (2017 Jetta) and I noticed that you couldn't go into the settings menu while the car was in motion. Is this something new? Nothing is locked down on my 2015 Golf R.
How about those with newer models?
Veejster
Seattle, WA
Yea they were all blocked on my '17 and it was massively annoying when I wanted to make changes on the fly. I tend to switch back and forth between DCC modes in Custom. I ended up just unblocking them all with VCDS.
Baldilocks73
Delaware, U.S.A.
2015 Golf R
Yeah, I am not sure I understand their logic. I mean, going through radio/XM stations and programming destinations is just as much a hazard as changing settings.....(shrug)
o_a_ravi
Could you please share, how you were able to do on the VCDS ?
I was checking the Long Codign and Adaptation channels on the 5F infotainement module, but wasnt sure which parameter exactly.
Thanks,
Ravi.
brian.tully
New York
2017 VW GTI Autobahn
Thanks,
Ravi.
+1
I'd like to know how to do this in VCDS as well. I haven't seen any info online on how to do this. Thanks!
o_a_ravi
Played around with the 5F Infotainement Controller Adaptations and was able to get it work.
Below is the steps to enable blocked settings menu items for Car (General Settings), Media, Phone and Radio
1. From VCDS, select Controller Module 5F-Information Electr.,
2. Enter Security Login code = 20103
3. Under Adaptions, Query for the channels listed below and set the value = NON_BLOCKED (Blocked means, settings not available in motion), for each of them.
IDE11502-ENG127601-Locked menu contents-FB_CAR_0
IDE11502-ENG127612-Locked menu contents-FB_CAR_11
IDE11502-ENG127613-Locked menu contents-FB_CAR_12
IDE11502-ENG127603-Locked menu contents-FB_CAR_2
IDE11502-ENG127604-Locked menu contents-FB_CAR_3
IDE11502-ENG127608-Locked menu contents-FB_CAR_7
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7
Worked for, try and let me know if it worked for you.
Thanks,
Ravi.
xXShadowXx
Texas
I'm having the same issue with my 2017 Passat R-Line, would the above information work with that as well? & if so what are the items need in order to do the job, please & thank you
Hotfart
LFK Kansas
Same here, did this a couple weeks ago with VCDS and it worked flawlessly. Assuming it will work the same with OBD11 (if your build date is pre-2017). It slipped my mind until now to come give my thanks to o_a_ravi for posting instructions. So, thank you, o_a_ravi!!!
