Codeca
- Pasadena, CA
- 2016 GoRf DSG
Title^
Purchased my 2016 GoRf a few couple months back, and its time for an oil change. Could I use an oil pump with engine flush? Common sense says no since it would sit in the pan and be recycled...but there will also be some running in the motor regardless. But if it sits in the pan leftover, will it be enough to damage anything? Planning on also using ceretec with leichtlauf from LM. From what I've read, there's about .1L leftover after using the pump, correct?
Also a bit off-topic, is it best to use the pump on level ground, or at an angle? Wondering since my street is at an angle(tilted to the right or left of the vehicle a bit). This is also my first oil change on my own, and the first car I've really wanted to take care of!
