Can anyone help?
Ryanw0
Michigan
2015 Volkswagen gti
So I just bought a 2015 gti 4 door with 152000 miles. The car has a lot of parts on it with it sitting around 400hp. So anyways the torque mount or “dogbone” mount snapped and i didn’t realize until later on when I heard a scraping noise coming from underneath the car. The car also has a shredded up belt and it leaked almost all of the coolant out. I feel like it was a domino effect of stuff breaking but I’m not too sure and was hoping to get some feedback, thank you!
Ryanw0
Michigan
2015 Volkswagen gti
I was wondering if the belt being shredded was because of the mount breaking or if something else caused it to happen
daconchslop
SC
ACS SE/Tech
Probably crapped out OE mounts allowed too much motor movement, snapped the pendulum arm causing the serpentine belt to make contact with the radiator fittings.
Have you checked for any coolant loss? Looks pretty moist around that area.
El_bigote_AJ
Las Vegas
2019 GTI bunny
Cts mount*
uberdot
Ten Forward
Silver 2017 6MT
Did it just rub a hole in the radiator hose(s)?
uberdot
Ten Forward
Silver 2017 6MT
Looks like he lost a headlight too?
Ryanw0
Michigan
2015 Volkswagen gti
I got the belt, coolant and a performance mount kit ordered today and on Thursday I’m going to order the connector, thank you for all of the help!
imthanick_a
Ohio
This same thing happened to someone who incorrectly installed their dogbone mount insert so I'd venture to say that is the root cause and only issue
2slowvw
Moderator
VA
2022 Tesla Model 3
Luckily doesnt look like too much damage and relatively easy job to get everything fixed up. Chances are you probably needed a new serp belt anyway for general maintenance. Good luck.
