Subliminal
- Vegas
- Slow FWD VW Hatch
you took what i said and assumed a whole bunch of incorrect things from it. just bc you can't figure out how to shift it smoothly and quickly doesn't mean everyone else cant eitherThe first two don't get it. 2018gti gets it.
All the discussions of rev hang I've seen go this way. Half the people swear they have no rev hang, or at least they can shift perfectly smoothly.
It's not a question of whether you can shift fast. It's a question of passive rev matching. Some of us actually care about preserving our synchros for the life of the car. When you shift fast from 1-2, we're not saying we can't get it into 2nd right away. It's that we can feel the resistance of the 2nd gear synchros as we jam it in. If you let out clutch at 3000 RPM in 1st and shift to 2nd quickly, the RPM might be 2500 when you shift, but 2nd gear wants to be in 1500. That is a significant difference that the synchromesh has to work to equalize in a fraction of a section, and that wears it down. It also feels incredible when you get a perfectly rev-matched shift--there is almost zero resistance to the lever as it slides in. Mmm hmm. Oh yeah.
If your idea of shifting "smoothly" is the shifter goes into gear quickly and the car doesn't jerk, you are totally missing the point. You can drive a manual car "smoothly" by relying on the synchros to rev match for you (=transmission wear) and feathering the clutch a ton (=major clutch wear). The rest of us are trying to avoid those things. Rev hang makes it hard.
i was tuned on stock clutch for 2.5 years with zero slip, so clutch wear wasn't an issue at all. only reason i upgraded the clutch was bc i had an opportunity to install a new (better) one for $300.
if you really struggle with rev hang that much you could always turn on the A/C lol
