As
@JC_451 mentioned, ignore anyone attempting to leverage their rarity. What is actually rare is someone looking to buy an R right now hah, you have all of the leverage. Look for any signs of modifications. For me, anything at all is a no-go even if the car is CPO. Simple things like an intake or an exhaust are easy to spot but also the easiest to swap back to stock. On these cars if nothing sticks out, look for more PITA things to swap back out like:
- Front-mount intercooler (time consuming to swap back out)
- Springs (time consuming to swap back out)
- Stiffer suspension or motor mount bushings (not worth the resale cost savings, most owners would leave them)
- Jiggly driver's left A/C vent (signs of running P3 or other vent gauge)
- Turbo muffler delete (if gloss black or polished, its not stock and they are kind of a pain to swap)
Check the service record, if it has over 40k miles DSG should have been flushed as part of its 40k service. Look for coolant stains on the hood liner & firewall from coolant leak/pump failure (not bad, just make sure the fix is present/verifiable in its service history).
Don't forget that an economy Enterprise rental is only $35/day and enterprise will actually pick the car up for you if wherever you're buying a car is within like 10 miles of the closest enterprise. Same with Budget but Enterprise seems to be the most reasonable. If not, your salesman will likely give you a ride to return it if you end up closing a deal on the car. I can't remember the last time I purchased a car locally. I'm OCD about rust so I regularly drive a multiple states away to grab gems.
