Burger Tuning JB4 Golf 1.8TSI MQB specific information thread
ZuMBLe
NY
Alltrack 6MT
Yup.. the name of the game is figure out where the limits are first, then tweak up as much as you're comfortable. Some of these other guys have some known good numbers to plug in though. I think @goodvibes has such numbers. I actually don't have a lot of experience tuning the JB4 with a stock ECU, so my process will always be get rid of the knock and start pushing back up.
goodvibes
IL
It's so gas dependent. Maybe try,11-12-12-13-14-14-14-14-13-12-11-10.
goodvibes
IL
I'll know more in a few days, LOL.? I'm setting fuel to 60 when I do this time. My afr was fine but trims were very high 40s the last time I tried max runs. May have affected overall advance a bit.
Has he run maps 2 and/or 3 just to see what's up
@mattcarr, if you haven't, running maps 2 and 3 are good to get a baseline. start at 2 and don't run 3 until we see where 2 is at.
goodvibes
IL
Try map 2 and see how it looks. Mine is not holding 5.5 psi peak on winter gas. Here's one I ran today that will need to be lowered a bit until summer gas is back. 70*, uphill. Basically, the entire map needs to be lowered ,5 psi and 5k, 1psi. The boost curve will then have the right sort of shape for the 1.8. I suspect I'll be able to run more in summer. The target #s will give you that log's map values if you average up to the nearest 1/2 number.
https://datazap.me/u/goodvibes/log-1616450436?log=0&data=1-3-4-11-25-26-27&zoom=77-148
I'm going to set it at 1-2-3-4-5-5-5-4.5-4-3-2-1 and wait for summer gas.
ZuMBLe
NY
Alltrack 6MT
Set it to what works now, the car *SHOULD* add boost as needed when using additive. I think IAT 60 to 70 is the best temp to set the additive target curve.
goodvibes
IL
The gas is still a variable. Winter gas is more volatile and probably can't hold as much boost. That said, you're correct for a year round set it and forget it map. I'll use those last settings and log again in the middle of May and see what happens.
mattcarr
Rockville, MD
2016 Golf SE 1.8 TSI
Try switching the JB4 to "additive" mode instead of absolute mode. Enter these settings in to the specified RPM fields.
1500 - 3
2000 - 3
2500 - 3
3000 - 3.5
3500 - 3
4000 - 3
4500 - 4
5000 - 5
5500 - 5
6000 - 4
6500 - 4
7000 - 4
Get learned:
https://datazap.me/u/mattcarr/third-gear?log=0&data=1-3-4-11-15-25-26-27-28&zoom=50-180
IGN1 is Timing advance (good)
IGN2-4 is knock (bad)
DME_BT is the ecu's factory programmed boost target value
Target is your JB4 programmed additive value. It's either an absolute value (car tries to reach the value), or additive value, JB4 takes the value then adds it on top of the DME_BT value for a final boost number.
Boost: Logged boost value.
Thanks, I tried the additive settings. What I now understand about the latest log is that knock is zero through third gear, which is good. Target plus DME_BT is close to Boost but not exactly, I’m not sure if that’s good. I’m also not sure what signifies good Timing.
https://datazap.me/u/mattcarr/additive?log=0&data=1-3-4-11-15-25-26-27&solo=11
ZuMBLe
NY
Alltrack 6MT
Make the 5000 value 4, make the 6000 value 5.
You don't want DME_BT to be close to Boost. The further apart you can get them without much correction, the more power you're making safely over stock.
You want to see that IGN_1 number going up like it does in your third gear pull.
mattcarr
Rockville, MD
Okay, made those changes. The temperature was 55 F for these logs. It’s warming up here.
https://datazap.me/u/mattcarr/5k-4-6k-5?log=0&data=1-3-4-11-15-25-26-27
Here’s a log of Map 2.
https://datazap.me/u/mattcarr/map-2?log=0&data=1-3-4-11-15-25-26-27
ZuMBLe
NY
Alltrack 6MT
goodvibes
IL
try this if you get a chance. 1-2-3-4-5-5-5-4.5-4-3-2-1.
mattcarr
Rockville, MD
Run your pointer through the map 2 log, note the targets at the 2500,3000,etc positions and put them in your Map 6. You have a good starting point there.
Okay, this is what I found:
1500 ?
2000 4
2500 4
3000 4
3500 4
4000 4
4500 4.5
5000 4.8
5500 5.3
6000 5.4
6500 ?
7000 ?
Should I try these exact numbers in Map 6? What would be good for 1500, 6500 and 7000? Thanks.
Okay, I will try it this week.
Should I still try this? How about Map 3? Thanks.
goodvibes
IL
Stay with additive for now and I think my #s are likely a better starting point than map 2 though both are fine. Point is to run something for results so you can get feedback.
ZuMBLe
NY
Alltrack 6MT
1500 ?
2000 4
2500 4
3000 4
3500 4
4000 4
4500 4.5
5000 4.8
5500 5.3
6000 5.4
6500 ?
7000 ?
1500 3
2000 4
2500 4
3000 4
3500 4
4000 4
4500 4.5
5000 4.8
5500 5.3
6000 5.4
6500 5
7000 4
