Should I drop the boost a little bit? So basically fueling is running out of capacity?
There looks to be some other issue. That car's ECU is probably deciding it needs to go to EGT protection mode which makes it go 10.x:1 AFR which the HPFP looks like it can't keep up with for the air flow that car has. On my car, if FP_H drops below 8 at full boost, the car will cut power momentarily.
