Well, it looks like you have room for the JB4 and raising limits. Time for Zumble and/or George to help you tweak.yeah that's the next question is if I stack or not. Likely going to resell my jb4 unless I go real crazy with it
Well, it looks like you have room for the JB4 and raising limits. Time for Zumble and/or George to help you tweak.Moar boost!
I have a mk7.5 1.8t golf with an is12 and have the opportunity to pick up an is20 for cheap. I was wondering, can I run an is 20 on map 1 or map 6 and be fine with out any other modifications to my car? I don’t want to make lots of power, just something equivalent to stage 1 is12. I have swapped an oem gti turbo back exhaust on my car with a second cat delete, k&n drop in filter and I have also done a clutch delay valve delete. Do I need to do any other mods to support the is20 Or will I be fine to just bolt it on or should I just stick with the is12
Any clutch issues if I put low boost in the lower rpms. Any body have any map6 setting that could work well with low boostLots of us have run just an is20 with no other mods at all and had no problems. JB4 + is20 is a really nice combo and it is very reliable.
I’ve already maxed out my is12 it doesn’t seem to be making any more boost that’s why I wanted to jump to a is20I have an auto so i can't comment on that. But I would start with your IS12 map 6 settings at first and then slowly add boost to the 3.5k and up. My settings for my is20 + jb4 are a few post back
hello i have a vw mk7 tsi 1.8t map 6 with a downpipe. what boost should i try to get on map 6? target wise?
Wrong thread. https://www.golfmk7.com/forums/index.php?threads/is20-instalation-guide-1-8t.341508/So I’m going to install an is20 on my mk7.5 golf 1.8t in the next coming weeks and I was wondering what advice you guys have in terms of installing it and weather I need any other Bolton’s to support the Is20. Also do I need to adjust the wastegate voltage or will it be okay?
OK. 87 degree day run on map 6 with these values. 11-13-14-15-16-16-16-16-15-14-13-12
https://datazap.me/u/goodvibes/log-1590357386?log=0&data=1-2-4-11-25-26-27
This is 1lb less boost than a cool temp run I had with some timing adjustment. I may put 1/2 lb back in 2500 up as I don't mind a little timing adjustment but thought I'd run it a bit more conservative on this pull since I've never done one in summer type heat. This is definitely the boost curve for my car and gas. Now it's simply a matter of how conservative or aggressive I want to be.
For those with a stock 1.8tsi, opened airbox and less restrictive filter, this curve with a couple/few less pounds of boost across the range would likely be a good place to start. Run logs and add a pound at a time until you get some timing adjustment and decide if your willing to have a small amount of pull or not.
