So who is the JB1 geared for? And the JB4?
Is the JB4 meant for people going big turbo upgrade, etc?
And is the JB1 meant for stock or full bolt-on users?
The JB1 is geared for people who want to put a unit on and forget about it regardless of hardware. The maps will eventually be tailored for this with some options to customize. Its a affordable unit so entry level.
The JB4 is for people who want to be more involved in the tuning of theirs cars. It caters for more mod variances and the logging feature and code clearing is added plus.
Thanks for explaining. I'm new to tuning so I don't really know what other variables there are. I just thought the JB1 has a pretty complex table as an entry level.
Does the JB4 work the same way where it's a plug and play that "intercepts" the signal to the ECU?
Do you have a ballpark on how much the JB4 will be?
Yes slightly more than the peak of the punched in numbers in the rpm section, we not certain which direction we going to go with. If users find map 6 more useful than map 1 we going to lock the boost curve in 1 and 2. When boost safety is reached in map 6 it will default to map 1 for safety reasons. The GTI or R does not over boost easily and only happens if there is extreme throttle closure. I need to decide in the next few days which way to go, either way we will have both firmware choices available so people can have the options to choose. Would also like to hear opinions of users of what works for them.
When you say "lock the boost curve in 1 and 2",would boost safety not affect maps 1 and 2?
Its a possibility I am considering. Then guys who want to be flexible have got map 6 to work with.
Hi George, it kinda sounds like you have to live within the constraints of the existing user interface, is this correct? If yes, then I think it makes sense to do what you have suggested. Let me see if I understand you correctly. Would it work like this?
Boost Safety - JB won't ever increment boost higher than this maximum value. For example, if the stock ECU max boost requested is 14.5 PSI (GTI), then a Boost Safety value of 4.8 means the ECU will now be able to request up to 19.3 PSI via the JB.
map 0 - stock
map 1 - default, modest and safe. Boost Safety setting defines highest amount of boost (+ PSI) that will be added to stock boost along the predetermined "modest" boost curve in the firmware.
map 2 - more aggressive. Boost Safety setting defines highest amount of boost (+ PSI) that will be added to stock boost along the predetermined "aggressive" boost curve in the firmware.
map 4 - meth? Does this still require using another map as I heard before, or how does this work?
map 5 - track?
map 6 - User Defined Adjustment - boost by RPM. If Boost Safety value is exceeded for any RPM's Map 6 Boost Value(i.e. user makes a mistake in data entry), then it will fall back to map 1, since the programmer can no longer be trusted!
Fuel Open Loop - will apply to all maps. (Will this be able to be further tweaked in map 6 via AFR bias?)
Would map 1 and 2 give a constant 4.8/5psi over stock or does it have a predetermined curve for the added boost?Slightly different.
Map 1 Fixed boost add 4.8 approx
Map 2 Fixed boost add 5.2 approx
Map 3 Meth
Map 6 variable boost for guys that want to adjust
Predetermined curve. These should be determined from a pool of figures I am receiving and logs.
Slightly different.
Map 3 Meth
Does that mean that map6 will have a smoother experience with higher low-end acceleration?
