Hammersticks
- Bay Area, CA
- '16 GTI, '18 e-Golf
I have a serious case of Reverse Rake with my H&R springs... Instead of adding on the back the TT Rubber Pads or the ED spacers, can I go lower by cutting my front bump stops?
I want to level the drop a little more and I know I can achieve this by going higher on the back.. but I prefer actually going lower on the front. If cutting them will work, then I found my solution.
Thanks!
I assume they were installed correctly?
To answer your question, no. Unless your front springs were so compressed they were resting on them...but then you would have way bigger issues on your hands. The bump stops are just resting around each damper’s piston until the spring is compressed enough for them to be needed to stop the compression. That’s not when the car is just sitting there.
The springs are dictating the ride height, not the bump stops.
