Building Otto
Ezekiel81923
Royersford, PA
2019 Volkswagen GTI
Great thread! Did you ever get the CEL to go away with that track slag DP?
The CEL is off because the EQT tune turns it off. If I were to flash back to stock to get inspected the light would be on as the car sits now.
My inspection expired 4 months ago so that's on the short list of things to sort out. I have a J-spacer that I need to install but I need a new exhaust clamp first before I take it all apart (for when I put it back together). I can't get the O2 sensor off without pulling the DP out.
I'll keep you posted when I get around to it.
19birel
Pittsburgh
MK7.5 - MK4 - B8.5
Oh I thought CELs couldn't be shutoff anymore with Accessport tunes, that's cool. Interested to hear how the J spacer goes!
Ezekiel81923
Royersford, PA
2019 Volkswagen GTI
That may be true. I bought my tune over a year ago and haven't kept up with everything as well as I used to. My tune turns the light off, the secondary O2 sensor is unplugged so I'd definitely get a CEL if it wasn't turned off.
Ezekiel81923
Royersford, PA
2019 Volkswagen GTI
I didn't take a ton of great photos but I can confirm, this was a pain in the ass.
Getting the bumper off is easy. I had a new grille so I didn't have to remove that but I have to imagine that would've been impossible given how it clips in and how hard it was to get the new one in. I re-used the stock spoiler, fog lights, fog light flares, fog light trim and the two big structural pieces that the fog lights screw in to.
With the benefit of not needing to retain my stock bumper, I dremel'd and/or cut a lot of the bumper tabs holding the plastics on and they were still difficult to remove. Got everything off but each piece either snaps into the next piece or screws on top and it's all very painstaking trying not to break anything. Took about 5hrs from start to finish, which included having to get the cutting wheel out to remove some stubborn bolts from the aerofabb splitter so I could install the new one into the stock spoiler. Also realized one horn was not bolted to the bracket, just kind of was swinging around from the wire. So I got that bolted back up. Also got some loose belly plastics re-secured better so they don't flop around as much.
Paint on the new bumper does look nice but there were three areas where they didn't prep it very well and there is dirt or something under the paint. Wasn't pumped to see that after rolling around on the driveway floor for a few hours but they are small imperfections and overall the bumper does look way better than the one I took off. From 3ft you'd never see them, the bumper and I were very intimate for a while so I noticed.
So the lesson here is: don't assume that little piece of debris in the road will fit under the car. It won't. It'll break your front grille, which will then cost you lots of time and money replacing everything.
Ezekiel81923
Royersford, PA
2019 Volkswagen GTI
Just can't win sometimes.
Hit a pothole changing lanes this morning. This time of year it is still/already dark when I am commuting to and from work so it's a crapshoot sometimes. Hit it hard enough that it didn't feel good but the wheels had survived similar in the past. Not this time.
Can only see that the front drivers side was bent pretty good. Rear same side hit too, not sure if that is dented on the inside or not. Will take everything off and see what kind of shape all 4 wheels are in before ordering replacements. Tires need replacing anyway so the winters will go on soon regardless. Holding air right now.
This is becoming a Repair Journal more than a build journal these days.
19birel
Pittsburgh
MK7.5 - MK4 - B8.5
Noooo, sorry to hear about the wheel damage man, that sucks
Ezekiel81923
Royersford, PA
2019 Volkswagen GTI
Yea, pretty big bummer.
Initially saw this as an opportunity to get new / nicer wheels but I really like the look of the rennforms so I'll probably just snag two new wheels and have one as a backup. They are still in great shape, minus the bent one.
Trying to decide on tires right now since the whole set needs to be replaced.
Ezekiel81923
Royersford, PA
2019 Volkswagen GTI
Purchased a new set of Rennforms and Federal 595 RS-Pro's but won't see them before it's time to put the winters on so they'll be stored safely until spring.
Seemed easier to get a whole set delivered to my door mounted, balanced, and ceramic coated since I need all new tires anyway. I'll keep two of the old wheels as spares since I know I dented one and assume I damaged another.
When I bought the original wheels they were on 595 RS-R's and they had been tracked at least twice prior so definitely not full tread. I managed to get two long summers out of them, close to 20k miles, but they are basically drag radials now. I really liked the RS-R's. They are noisy but they grip. The Pro's are lighter and are 200tw vs 220 on the RS-R's and I'll have full tread so looking forward to some noticeable improvements with this tire.
Ezekiel81923
Royersford, PA
2019 Volkswagen GTI
Changed the oil. I have no idea how long it's been but it looked pretty good so I'm going to start keeping mileage here because I'm definitely wasting money going by feels like it's time.
Switched from Mobil 1 0W-20 to Liqui Moly Molynen 5w-40 which is a little closer to what EQT recommends with their tunes.
Mileage: 37,881
Ezekiel81923
Royersford, PA
2019 Volkswagen GTI
Also updated the build sheet (aka the OP):
EQT Standard Vortex
Sachs Race Clutch w/DMF
iABED Rear Main Seal
SC Skunkwerks RS3 LPFP
Euro Manifold
Charge Pipe
PR MPI w/980cc Injectors
PR Fuel Lines
Fluidampr
MAP/PUT Sensors
EQT Custom Tune
Don't think I'm missing anything there. Just going to do it once and do it right. No E85 so still planning on 93 and hoping for some semblance of reliability by not turning it up to 11. Currently shopping shops as I have neither the time nor the expertise to do this confidently. Anyone with rec's in the SEPA area? NGP and APTuning are both about an hour away in different directions and on the list. A euro shop also just moved into town and I'll chat with them but they are lower on the list.
daujin_mk7
PA
2016 GTI DSG
Euromotive Autohaus in Aston, PA was highly recommended to me. My father got some work done on his BMW x6 M there and gave positive feedback as well. I think they add like $15 on top of their shop rate for customer supplied parts.
Ezekiel81923
Royersford, PA
2019 Volkswagen GTI
Right on. Thanks man. They are not too far from where I work so I'll try to stop by and see what they think. I normally suck at price shopping but given the extent of the work I'm looking at doing I think its worthwhile this time.
daujin_mk7
PA
2016 GTI DSG
Not sure how close your work is, but they will pick up/drop you off within a five or so mile radius while they work on your car.
daujin_mk7
PA
2016 GTI DSG
Are you still liking the Powerflex Race Hybrid insert? I had BFI stage 2 (90a) but swapped out to BFI stage 1 when I installed the BFI stage 1 engine and trans mount.
