Parts Express has lots of
options. I use
these for my home stuff, but any of them should be fine.
Just got some Dayton speaker terminals. Thanks for the reference!
What is your plan for the pillar trim? Mount the pods right to the pillar and then make the trim fit around them? Looks like you already cut the trim too short to make it an easy change
If you bond the pod to the trim you have to have enough room for the trim to pivot if the airbag goes off.
Yeah a lil' short at the moment. I'll have to re-bond the lower half of the a-pillar and create a sort of opening for the pod. That is a good option too (bonding the trim). Though, the area where I cut seperates the airbags from the pod itself, so they'll never interact if they ever set off.
That is fair, just another option though. Maybe he decides to procure that sub and build his own. personally, I'd say build it into the inside of the rear seatback.
I'll opt to build my own box. I did purchase a pre shaped box for 200$... well.. it was that price for a reason. Here's a screen shot of PSSound's approach. I'll follow in the same suit and build a sort puzzle pieced speaker box. I think it's really creative. You'll have a great bond of material, a custom fit, but also dense material to dampen the speaker.
Welp I started working on my kicks again (just the passenger one. Luckily I can stuff 0.25 cubic feet of volume behind the speaker which, according to Andy W. of Audio Frog, is ample. Building it with a little bit thicker ply wood @ 1/2".
