I've also had the exact same thing happen coming out of tight 2nd gear right/left turns after heavy braking. Where I goto give it gas and the car doesn't want to accelerate at all, totally stock engine with a "normal" BFI can here . Also TC/ESC totally off via obdeleven, with 200tw tires, Beside no power hesitation when I would hit the gas, a noise like some kind of "hydraulic squishing" is the best way I could describe it. I've looked out the rear view mirror when this occurs to check if there's a never puff or cloud of smoke (as is typical) but never seen any. If it is the PCV / oil doing this, I assume I'm only not tossing a smoke screen because the catch can is catching. Versus dumping into the intake.
I mentioned it to a shop at a track day a couple years ago, they figured it was some stability control freaking out right after the near ABS stop and hard turn, the getting right back on the gas. Unsure that's even possible though it was a free suggestion.
Had a good time on Saturday too
@BGrade ! I was in the silver GT4 on track with you some.
