brake fluid recommendations
jay745
What Would Glenn Danzig Do
Slightly Outside Chicago
Mk6 racecar, Tacoma
RBF600 is very hygroscopic.....needing to be changed at shorter intervals, especially in humid conditions .
On my bikes I will switch it out after a couple of track days. It is easy to see and feel the difference with the fresh fluid.
I thought RPF600 was terrible for track days, I got pedal fade after 10 minutes and had to back off. Switched to SRF and will never look back, it's expensive but very worth it. 30 min sessions and the pedal is firm the whole time
imthanick_a
Ohio
otbiker57
Texas
17 GTI
Here's maybe a silly question... can the GTI be flushed by conventional means? Two person, hold the pedal down routine?
I recently bought a 17 SE and it's time.
TIA, Marty
OldVWFan
NW Arkansas
17 GTI Sport
TIA, Marty
Purchase a power bleeder such as Motive Products or Schwaben, much easier, faster, and less chance of getting air in in the system. Remember to get a catch bottle or make one.
NCM
Fort Wayne, IN, USA
2015 Golf R
Not unless you run the system dry and introduce air to the system. A straightforward bleeding through, no need to cycle the abs.
You will then retain some of the original brake fluid within the ABS pump system. However unless the two fluids are incompatible (not likely), or the original is so old it's turned into bat piss, this should be no big deal. Even then you can go out and activate the ABS while driving — easy on a wet road — to flush that remainder, then rebleed.
Neil
docwyte
Denver, co
I've never had an issue with the fluid remaining in the ABS system. I just bleed/flush the brakes the normal way and leave that alone.
Ace92028
San Diego
does anyone actually change their brake fluid that often? mine is fine and its never been changed
M3bs1
North Augusta SC
If you haven’t ever changed it on a 2015 car, it is NOT “fine”. Not only has it’s boiling point been reduced, but you can actually absorb enough moisture to damage components like your ABS unit, or even cause caliper sticking issues. Learned my lesson years ago the hard way.
