Brake caliper temperature possible issue
Dario
Zagreb,Croatia
7R
Hello. Installed a full new set of Stoptech's st40 kit on the R, all bed in procedure followed as per instructions, they perform perfect but the right side is more warmer that the left( the caliper specific) not by much. but in lets say normal driving city, the left is stone cold, the right is warm-ish. Can a wheel bearing cause this? ( no sounds or anything that would indicate wrong ) or something else ? Any info from where to start checking helps.
PS: dont know if it did that on the stock brakes because I did not payed attention to that
Acadia18
2019 Golf R
Did you bed in the pads properly?
"all bed in procedure followed as per instructions"
It's the very first sentence of the post...
Dario
Zagreb,Croatia
7R
yes. the bed in was done as stoptech has in the papers
I think that we are going to replace the wheel bearing and see
Mini7
Charlotte, NC
2017 GTi Sport PP
Right side always seems to run hotter.
Both on my OEM PP brakes and with my BBK at the track. Figured this is due to XDs.
Dario
Zagreb,Croatia
7R
Ordered new bearings just for sake, then will go to a ramp and meassure the braking force on wheels. Got a few people saying the ABS pump could be faulty
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
If its a new set of calipers & pads & everything moves easily by hand...I'd say check your ABS unit for fault codes & as you say test it on a brake force dyno to se if there actually is an imbalance..
R Golf
Lenox, MA
You may have a pad dragging. Were the pads loose or easily moved when installed in the calipers?
That's my thought. Had this issue on another car of mine. Sometimes you can hear this if you have someone put their ear very close to the wheel as you slowly roll by.
Wheel bearing could cause this, but usually you can hear some type of noise in turns. With right side, you may be able to hear it more in left hand turns.
Dario
Zagreb,Croatia
7R
no fault codes on it. but will test, maybe the abs unit is faulty not giving correct pressure to both sides
Dario
Zagreb,Croatia
7R
So had the brakes tested
FL - 3664 NM
FR-3971 NM
RL-1952
RR-2439
epb
L-2093
R-2178
so we have suspicion that the ABS pump is the faulty piece of the puzzle, and the car has no faults on vcds or odis
  • Sad
Reactions: q74
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
FL - 3664 NM
FR-3971 NM
RL-1952
RR-2439
epb
L-2093
R-2178
The rears on the EPB motors is only 85Nm out left to right, but those same calipers using the brake hydraulics are 487Nm out left to right??...thats the brake hydraulics system...servo? master cylinder???..
I don't think its the ABS unit as that really doesn't apply pressure its your foot on the master cylinder/brake servo??
