nok513
- Orange County, NY
- 2020 VW GTI S
Thank you for clarifying.does not matter as the clutch is a separate circuit even though it comes of the same reservoir.
If you could post that procedure that would be great. Dealing with a soft pedal after the last service in wife’s car. Would rather bleed myself and if still a soft pedal would do that procedure before taking it back to the dealer.Erwin guide for the 1.8T. Pre-bleed, which I'd have to look up but assume is low pressure at the top. Standard below. They have a post bleed procedure if you still have soft pedal I can post if needed:
6.4 Hydraulic System, Post-Bleeding Perform a post-bleeding when: ♦ The brake pedal travel is too long, or the so-called soft brake pedal A second technician is required during the post-bleeding. – Connect the -VAS5234- – Press brake pedal forcefully and hold. – Open bleeder valve at brake caliper. – Press brake pedal down onto stop. – Close bleeder valve with pedal depressed. – Release brake pedal slowly. Note This bleeding procedure must be performed five times per brake caliper.If you could post that procedure that would be great. Dealing with a soft pedal after the last service in wife’s car. Would rather bleed myself and if still a soft pedal would do that procedure before taking it back to the dealer.
Before removing the old calipers, lodge a 2 x 4 between the seat and brake pedal to keep it depressed while you are swapping the calipers. This will help prevent fluid from going everywhere and reduce the amount of air introduced into the system.Another question.. I'm doing the Macan caliper swap this Friday. I have all the parts and power bleeder lined up. Is the 30psi per caliper, or does it need to be maintained throughout the whole process? Or is the 30psi only required to flush out the ABS and use a lower psi for each caliper?
I hope I'm making sense here..
Thanks again all...
Before removing the old calipers, lodge a 2 x 4 between the side and brake pedal to keep it depressed while you are swapping the calipers. This will help prevent fluid from going everywhere and reduce the amount of air introduced into the system.
30 psi through the bleed I would think. You'd want to maintain the psi as you work through the bleed order.Thanks.. Will definitely do that. What about my psi question? Is the 30 psi per caliper?
Do i fill up the power bleeder with the same 1.5L of brake fluid and set it to 30 psi for post-bleeding?30 psi through the bleed I would think. You'd want to maintain the psi as you work through the bleed order.
Yes.Do i fill up the power bleeder with the same 1.5L of brake fluid and set it to 30 psi for post-bleeding?
