Mine left Czech Republic from Prague on Jan 30th. No updates since then and USPS informed shows no packages enroute to my house yet :-(
It's mine now suckaMine left Czech Republic from Prague on Jan 30th. No updates since then and USPS informed shows no packages enroute to my house yet :-(
I am going to measure the pipes when it gets in and go from there. Probably just get clamp if it matches up. Thanks for the infoThe VW clamp is great if you have matching sized pipes, it seals very well. Unfortunately I couldn't use it without either expanding the 60mm pipe, 65m reduction wasn't recommended or welding a sleeve over the 60mm and clamping it. In any case, I ended up welding it and the sound has definitely improved.
curious where you got the info about it not being recommended to use a 65 > 60mm clamp?The VW clamp is great if you have matching sized pipes, it seals very well. Unfortunately I couldn't use it without either expanding the 60mm pipe, 65m reduction wasn't recommended or welding a sleeve over the 60mm and clamping it. In any case, I ended up welding it and the sound has definitely improved.
I ordered mine on February 10, it shipped 2 days later, so I guess it's safe to assume that they have some in stock. FedEx's website originally showed a delivery date of February 17, but that didn't happen, unfortunately. The tracking info now shows a pending delivery status. I got updates when the package transited through Poland and Germany, and also when it landed in Memphis TN on February 18. No new updates since.I guess e-acca has them in stock and on hand. My order from Saturday just shipped out via FedEx this morning, or at least has a label made for it.
Ah gotcha. ThanksNo I think I wasn't clear... it wasn't recommended to reduce the pipe diameter on the 65mm side to 60mm. Not that it wasn't recommended to use a reducing clamp.
Separately, I couldn't find a 65mm to 60mm clamp that fit well enough and didn't leak, that's why I went with welding it on. All the other options would just add time/labor. If I had more time, I might have been able to get a good clamp, but I had a leak on my R56 and it drove me nuts every time I had the windows down.
Hope that clears things up.
I would guess they got snowed in last week. They’re probably playing catch-up after being closed for a few days.I ordered mine on February 10, it shipped 2 days later, so I guess it's safe to assume that they have some in stock. FedEx's website originally showed a delivery date of February 17, but that didn't happen, unfortunately. The tracking info now shows a pending delivery status. I got updates when the package transited through Poland and Germany, and also when it landed in Memphis TN on February 18. No new updates since.
