Diggs24
- de plains! de plains!
- 2015 GTI
Right, MK7s don't run that rich. You have a 7.5
It's great gas for 91ACN. Congrats. Lucky guy.
max on jb4 with e30 like 9-10 is good, some cars are maxxed out and get like 8 tho, depends on weather, gas %, other FBO mods. I think I have only saw like 1 above 11 and thats hooning
Sorry if this was asked many times before.
I drive a 2019 Mk7.5 GTI w/ DSG with the stock air box mod and a TCR muffler. I also live in California and don't have easy access to anything more than 91 octane gas. It looks like Map 1 is the only way to go for me? Will I need to posi tap the AFR wire if I'm only running Map 1 on the Mk7.5?
Thanks!
That extra fuel the 7.5s run really helps.
Hey, guys currently have a 2015 A3 running a downpipe IC Jb4 and an Is38+. (Stock size uprated internals and a bit better flow up top)
Just finished installing the turbo and ran great on Map 2 and decided to try out an aggressive map 6 I saw for an is38
I used this map on 93 octane with the peak set to 8.2. Ambient was about 75F
Car ran great from 1st to 3rd, but the log to me seemed a bit sketchy, I am kinda new to this still.
Checked codes after saw I had a 3 codes pending
P0087, though I've been dealing with this code since I was just JB4 is20 with everything else stock.
P0106
P0236
https://datazap.me/u/acehammer/map-6?log=0&data=1-4-18
Switched back to map 2 for the time being. Also planning on putting in new spark plugs and cleaning the map sensors. (Oil surged autocrossing about a week ago)
Any advice/criticism welcomed. Much rather be told I'm being an idiot by you guys than my mechanic
Hey guys,
I did a run of map1 and map2. How do they look?
map1: https://datazap.me/u/yungaxel3/3rd-gear-pull?log=0&data=1-3-4-6-11-14-18
map2: https://datazap.me/u/yungaxel3/3rd-gear-pull?log=1&data=1-4-6-11-14-18
I'm running on 91 octane in California. 2019 GTI DSG stock except the stock air box mod and TCR muffler.
Thanks!
Hm. Good call out. Throttle is at 100 thoughUnless im reading it wrong, it doesnt look like you are WOT. Pedal is only 60% pressed down. Better to go WOT for more accurate logs. If im mistaken, someone please do correct me.
A bit less E. Gonna be a balancing act though, if no intercooler. Summer heat demands more fuel to try and cool things off. Unless you have a 2019 .How do you combat the fuel system lean code? Less E more 93? Noticed it when scanning today.
Map3 stockish intake. Logging tomorrow
