Map 2 is an additive map, +5 psi over ecu_psi. The point of Map 6 is to adjust, not to keep it at "out of the box" settings...
I understand that Map 2 is an additive map -- but 5 PSI is the
PEAK added boost. It is not 5 PSI across the board.
I just installed my JB4 over the weekend. And, I have the bluetooth connect kit. But the app doesn't let you look at the settings for Map 1 or Map 2.
Based on my butt dyno, Map 2 pulls significantly harder than Map 6 in higher gears at higher RPM's. I have a stock 2019 GTI-S; and I'd like to preserve the clutch for as long as I can. Since I don't race my car, or drive overly aggressive, I feel like I can do that. It just so happens that the shipped Map 6 was designed specifically for someone like me.
Anyway, I'd just like to see what the settings are on Map 2, in case I decide to tweak Map 6 myself. Since I bought my JB4 used, I didn't want to bother George with this if I can get some feedback here.
