BMS VW GTI JB4 info thread
Drincc
Vancouver, Canada
2019 GTI
Now that I'm debating between switching off JB1 or just adding light support mods and keeping it (broken connector is the debating point), what's the theoretical limit that the JB1 can take before JB4 is required? I was considering an aFe or VWR R600 intake.
Clem604
Vancouver BC, Canada
2018 VW GTI
Intercooler>intake. If you have the funds do both!
shovelhd
Western MA
Here is the combined log of a few pulls
datazap.me | panpolanski | 08/25/21 Log
Now that I see my IAT's at WOT of 132F in an ambient temperature of 85, makes me wonder what they were when it was 98 yesterday...Could that cause the pinging/knocking? However, the time my GF took the car out it had been sitting in a garage (albeit on a super hot day and after I had driven it so it likely was heatsoaked) so not sure if that was contributing... Could I have fouled my spark plugs with the CRC valve clean? Plus, if that was the issue (the plugs), wouldn't I have misfires on a more regular basis, not just intermittently and only at high engine load @ low RPM? I don't know... also, AFR of under 10... that don't seem right...
Those short pulls give some info but a single pull in third from 2000 to redline then shift to 4th is a lot more revealing. It's possible that your valve treatment has fouled the plugs, but did you follow the directions on the can? Treat it at operating temp at idle with a bunch of doses, then dose it until it stalls. wait 30 minutes, then drive for 30 minutes between 3000-4000 rpm steady. I also wail on it full throttle for a few runs after that.
When was the last time you changed the plugs? Are you adding ethanol?
Panpolanski
Kansas City
2019 Jetta GLI
That log I posted has such a run in it (4th one in the log), I started in 3rd @ ~2000 RPMS and floored it until it shifted into 4th and kept it going for a second after, the pull subsequent to that one is a WOT 2-3-4th gear pull as well (I shifted manually into third a bit early on that one though). I did follow the directions on the can. The car has under 14k miles on it, the plugs have never been changed. Been running a JB4 for 3-4k miles maybe? I do not add ethanol (I do add octane booster frequently) other than what is already in the gas that I buy, which I suspect is ~10%. Thanks for the input!
Save your money and just get a drop in filter.
Panpolanski
Kansas City
2019 Jetta GLI
Set FOL to 60
put it on map6
1500 0
2000 1
2500 2
3000 2.5
3500 3
4000 4
4500 5
5000 5
5500 5
6000 5
6500 5
7000 5
So I want to add more boost up top and less down low…? With having episodes that sound like engine knock and an AFR of 10 is that a good idea? Why my AFRs running so rich?
