RisingFallens
- Raleigh
- MK7.5 GTI!
Is there anything he can’t do??
It isn't a clickable link.I did a couple of pulls today with the new FW on Map3! Whatcha think?
Logs
https://datazap.me/u/risingfallens/today’s-pulls?log=0&data=1-4
For some reason it’s not letting me save a hyperlink?It isn't a clickable link.
Try copy and paste.For some reason it’s not letting me save a hyperlink?
This should be blue and take you to the logs
https://datazap.me/u/risingfallens/today’s-pulls?log=0&data=1-4Try copy and paste.
Sorry.https://datazap.me/u/risingfallens/today’s-pulls?log=0&data=1-4
Doesn’t seem to like that either
Need to put the foot all the way down but looks ok otherwise but probably hot so not much timing advance.I did a couple of pulls today with the new FW on Map3! Whatcha think?
Awesome! I just filled up with 93 so I don’t have the room for it right this second. Think I should stay Map3 or start messing with 6?Need to put the foot all the way down but looks ok otherwise but probably hot so not much timing advance.
datazap.me | Risingfallens | Today’s pulls
If you have E85 around I would start blending 2-3 gallons/tank to get better timing advance and have some KR buffer, log to see if you need to raise FOL.
Stay map 3 but you can add E85 when you have enough room in the tank, it will blend and bond with the gas on its own.Awesome! I just filled up with 93 so I don’t have the room for it right this second. Think I should stay Map3 or start messing with 6?
I was looking at the MAP5 for the e30 blend. Did you run e30 without an e-sensor?Don't have too much fun, a little Ethanol really wakes these cars up! I made 325/363 full bolt on with my e30 map6
Correct I did not have an Ethanol sensor so it may not have been a proper e30 blend.. I just put 3-4 gallons of e85 and topped off with 91. Ran the car like that for months with zero issues.I was looking at the MAP5 for the e30 blend. Did you run e30 without an e-sensor?
Do you still have your map6 numbers? I saw you’re EQT STG2 now, but Looks like we run similar mods. Id be interested and trying it out!Correct I did not have an Ethanol sensor so it may not have been a proper e30 blend.. I just put 3-4 gallons of e85 and topped off with 91. Ran the car like that for months with zero issues.
I didn't really use map5 though. Tried it a few times. Map6 was my kill map and I usually drove around in map3
