mirtskhu007
- Republic of Georgia
on which map you did 289whp?
On which map you did 289whp?
It showed Map6 running 91 octane..
My JB4 arrived also with 60/3//5. I updated it yesterday to the latest firmware which should read 60/5//5 when completed. Load the "VW_JB4_OBDII_5A_3.hex" file to get you to the latest revision.
Go here for the file: http://www.n54tech.com/forums/showthread.php?t=50428
Post #3
Thanks man! sounds good. It already feels pretty smooth, so I'm stoked to see what the new revision has in store.
edit:
Also, will changing the boost by gear settings apply to all maps, or will it only affect map 6?
Hi,
I'm trying to fit the JB4 to my facelift GTI PP. Got an issue with locating the red AFR wire. Following the wires going from the top of the turbo to the connection, there doesnt seem to be a red wire. There's 5 wires - black, white, grey, yellow amd blue See attached photo. Any ideas guys?
I've also attached a photo of the plug above it just incase (second photo). There's only 4 wires going to this one - white, white, grey, black
Any help would be much appreciated. Many thanks,
David
Sent from my Nexus 6P using Tapatalk
Thanks George. Im running it on map 1 just now without the AFR wire connected.I got into contact with some of our dealers as well as customers with 7.5's. From what I have seen now they all have the normal plug as found in the pre facelift GTI with the same wiring.
I reckon the variance we are seeing is only for the 245hp performance pack. I am convinced the blue wire is the correct one especially if it goes to the red on the other side. I should have the diagram in the next few days though for the specific model and will advise accordingly.
There is no passkey just connect with the appThanks George. Im running it on map 1 just now without the AFR wire connected.
I purchased the jb4 with the Bluetooth module which arrived pre fitted. I'm struggling to connect my phone to the JB4. What's the passkey for the Bluetooth? I've tried 1234 and 0000 and other combinations with no success.
Cheers David
Since the JB4 causes the car run rich, will it cause excessive carbon buildup. I know on the mk6 gti/golf r they had problem of carbon buildup. What problems will occur in long run when this occurs.
Got some nice weather in buffalo today, good enough to enjoy map 1 on a little drive and I️ decided to finally update. The firmware update is phenomenal the car actually feels stock now while cruising, especially while casually accelerating in 2nd gear and still hauls ass like I️ remember when I️ put my foot down.
