Justgotohm
- Savannahish
- 2015 GTI SE SP 6sp M
I have a BMS IC installed, it went in without issue, no complaints.
This is the shorter IC hose I talked about earlier. Other than those two things intercooler went in fine.I did the same with the zip ties on my V2.
I am IS38 and I installed my BMS V2 a few months ago. Bms said the alignment tabs up top not lining up is normal and not designed to hold the intercooler. And also the longer IC hose on the drivers side was too short and couldn’t use. BMS said they could send me another hose if I wanted to...Duh of course it’s what I paid for. I still haven’t received a replacement yet and it’s been a few months now. Not sure if it’s Urotuning or BMS dragging this out.
I've had mine installed for 6 month now, works fine for me. Just had to zip-tie the upper left corner of the radiator to the IC because the slots of the BMS inter-cooler are not a great fit.
Yes, I tie wrapped the from the upper radiator inlet/outlet tube to the front chassis support.Upper left as upper driver's side? If so, I'll make sure and take a look at that area.
This, I had to so the same with my AMS ic, Though I don’t have BMS IC I skimmed some threads to find out how common this issue is, and seems like it can occur in all brands of OE location aftermarket ICs.Yes, I tie wrapped the from the upper radiator inlet/outlet tube to the front chassis support.
So the forge or are you recommending something that replaces the stock IC all together?Get a real FMIC.
