ruu1989
- Edinburgh, UK
Hi All,
My first post here! Tried searching first but couldn't find anything super-relevant, and hoping this is the right board for it.
About two months ago, the boot latch on my MK7 TDI failed - at almost exactly the same time (I am sure this is unrelated, but felt it might be worth mentioning), I stopped getting any hot air from the blower.
I took it to two local independents - one specialising in VAG, on not - both who were unable to see anything obviously wrong. On both occasions they plugged it into the diagnostic doodad and there were no fault codes, and the temp dial in the car appeared to register and feed-back correctly. The rad heats up to and sits at about 90c as it should, and it looks like coolant is at the correct level and flowing properly.
The blowers push plenty of air, but the temp dial has no influence on temperature, and it's worth noting that the A/C *does* work correctly.
I've also noticed, on very rare occasions, that I do get a *tiny* bit of 'lukewarm' air from the drivers-side dash between the window and steering wheel, if I have the temp gauge turned to max and the speed on 1 or 2, any higher and it just goes cold.
Has anyone experienced something like this before - or know what I can check next?
Both garages suggested changing the thermostat, likely at a cost of about £160, and with the added annoyance that the part can be one of two, and there's no way to tell until it gets opened up which part it is, so they'll need to strip it one night, find out what part it is and next-day it, and then install it the following day. It's under the inlet manifold, or something?
The alternative is to take it to VW and pay (at least) £110 for diagnostics, just to get a quote for the actual repair.
I'm a computer guy - I'd love to add that I know basically nothing about the mechanical workings of cars... I can change tyres and wiper blades - had a crack at changing headlights once but my hands were too fat.
It's starting to get colder and colder, and with a five-month old it's no longer suitable to just load up on blankets.
Help! Need to know what to do next! Anything I can check? Should I bite the bullet and take it to VW? Or have a go at the thermostat replacement.
