Blind Spot Side Mirrors
Suma Performance
WA
MK7
Tired of Blind Spot & Glare?
Then you'll need our performance mirrors, best blue wide angle convex. 3 advantages over other mirrors:
https://www.sumaperformance.com/
1. HYDROPHOBIC
It is water repellent. This provides clear visibility in rainy conditions to provide safety and driving performance.
Our water repellent feature is permanent. This feature is coated during our proprietary SOGEL manufacturing process. Unlike Suma Mirrors, other mirrors typically use spray-on that the water repellent feature eventually erodes. Suma Mirrors are hydrophobic and permanent.
2. TRUELY WIDE ANGLE
Suma Performance mirrors are R1000, whereas other mirrors are R1400. (The smaller the R-number, the wider the view). If you compare Suma Performance mirrors with other mirrors, you can clearly tell that you can see more objects in Suma Performance mirrors.
3. TRUELY ANIT-GLARE || COLOR DON'T FADE
Our mirrors go through a stringent, proprietary manufacturing process (SOGEL NANO process) that takes multiple steps/days to produce our signature, blue hue mirrors such that the mirrors themselves are actually clear and colorless (we have several patents and are the only manufacturer uses this process).
The reason Suma Mirrors look blue is because it absorbs all spectrum of the colors except the blue color that's pleasant to the eyes. Thus, Suma Mirrors effectively reduce glare (the yellow color spectrum, which causes glare, is absorbed).
Other mirrors, in contrast, use the vacuum coating process such that the blue color is actually coated on the mirror itself (unlike ours, clear/colorless mirrors that only reflect blue color). Based on that, they are not truly anti-glare because the glare is still reflected to human eyes. In addition, the blue coating will eventually corrode/fade.
TESTIMONY
"There’s not much to say except, worth it! I received these mirrors and the first thing I noticed is the excellent clarity and attention to build quality, pretty much OEM standards. The reduced glare and wider visibility is well worth the price of admission!... The online pictures just don’t do it justice. If you are on the fence about buying a set, don’t be, it’s worth it!" - Bobby from L.A.
Suma Performance
WA
MK7
You get what you pay for, especially for blue convex mirrors. Other third party mirrors have issues such as the blue tint peels away and bubbles up, the image isn't clear etc. Here is a forum threat already discussing these issues: Issues with other blue mirrors.
We guarantee OEM fitment and quality.
