Al_in_Philly
- Philadelphia USA
I’ve finally completed my modifications to my '15 R’s chassis and suspension. I’ll leave you in suspense (at least to the end of this posting) to let you know how it came out. But first, I should tell you what I was looking for.
I’ve been impressed with the overall package that the R provides. It’s multi-talented, somewhat sophisticated, and practical. Being city-dwellers who have to work hard to find street parking, it’s our only car. And though it always handled all of its roles well, I’ve never been happy with the feedback and feel between the road and the steering wheel. What I wanted was for the car to keep all of its utility and drivability but give me an awareness of the road that the car was somewhat lacking. I know it wasn’t possible to have 911 feel and handling (especially without sacrificing daily comfort and convenience), but I really did want to get at least a bit closer to that ideal. This goal was made even harder, because I didn’t want to lose any more ride-height in winter driving, so the stock springs were a must.
One of the first mods was to install a set of Advanti Hybris 19x8.5” wheels. I never was in love with the stock Cadiz wheels, so when I curb-rashed one of them, I bought a set of these flow-formed wheels, saving almost 5 lbs of unsprung/rotational mass at each corner. To be honest, I didn’t feel all that much difference in ride/handling, but they looked 100% better.
My next mod was to install a Eurocode front strut tower brace. My thinking was that making the front end even more firm would send me more info that was coming from the wheels. It worked to a degree. After installing the brace, I could definitely feel more of the road surface while driving; but still, it wasn’t anywhere near Porshe standards.
After I had about 20K on the car, I switched from the lame Bridgestone’s that came on the car to as set of Michelin Pilot Sport 4S tires. Huge difference. Not only more feel, but better grip AND softer ride. I can't recommend these tires strongly enough for DD duty. Still, I had miles to go before I slept.
A couple of months back, I installed an 034 rear sway bar, but kept it at the lower stiffness setting. My wife drives the car as well, and I didn’t want the rear end to break away in a panic situation. Still, this yielded a significant improvement in balance when going through fast sweepers. That alone helped make the whole car feel more neutral—I should have started here.
Last week I finished the job, by replacing the stock Monroe DCC struts/shocks with a set of Bilstein B6 DCC struts/shocks, replacing the lower control arms and bushings with a set from Black Forrest Industries (which incorporated RS3-cloned solid rubber bushings), and adding an i-Sweep power brace between the control arms and subframe. This step scared me. Not only because of the cost of the shocks, but because going with firmer struts and LC bushings might just ruin the driveability of the car. Happily, that didn’t happen. After several “spirited” runs up and down Kelly Drive (Philadelphians know what I mean), some bouncing through the potholes of South Philly, and some miles on I-95, I am not only breathing a sigh of relief, but am pretty giddy about how everything wound up working together.
I almost never used the “comfort” setting on the DCCs, as not only did I not like the loss of feel in that mode, but when going over bad potholes with the original shocks, I sometimes bottomed out. “Comfort” was reserved for long, straight, stretches on the Interstate. Normally, for around town driving I had the DCC set to “Normal” stiffness, which suited me fine. But now, with the B6’s, the softest setting is pretty much the same firmness as the old “Normal” setting, but with one, notable, difference: the Bilsteins take the hard-edge off of the transition between compression and rebound—they are amazingly smooth in that respect. So, driving around pothole city is maybe even a bit more controlled in the B6 “Comfort” setting than I used to feel with it in the original Monroe “Normal” setting. On the highway, the ride in “comfort” is not just more controlled than with the original struts set to “comfort” but even more controlled than in the original “normal” DCC setting.
With the Bilsteins set to “Normal” the car pretty much rides like the old “Race/Sport” setting, but with a lot more feel coming from the front end.
Going into full “Race” mode on the Bilsteins, on fast, smooth, curvy roads, however, is nothing short of amazing. The slight vagueness of the original suspension is totally gone. You turn the wheel and it just goes where you were thinking. Zero drama. I’ve been taking some of my favorite curves faster than I ever felt comfortable doing before, and I still haven’t come close to finding my limits. My guess is that it isn’t just the B6’s, but the combination of all the other mods working together—better than I even expected. The ride in the firmest setting isn’t “brutal” either. Yes, too harsh for really bad streets, but you can do general boulevarding in that setting if you wanted to. But for now, that setting is being reserved for when I want to reclaim my inner child.
I've heard time and again people say that after installing a stage 1 tune that "this is how the car should have come from the factory;" That is how I now feel about the chassis and suspension on my R right now.
I hope that this has been some help to you.
