witsbusa
- Philadelphia, PA
Hey guys.. I posted this question to RjRacing's build thread, but figured I would put it up here figuring more eyes might see my question and have some input..
I picked up a set of B14 coilovers and will hopefully get them installed tonight.. I have never messed with coilovers before, and am hoping to get some help with the adjustment / lowering process. From reading the product descriptions, it looks like install of the coilovers will lower the car a minimum of 30mm and up to 50mm using the adjustment. Can anyone give me any help with the height adjustment? I am looking for a little bit more drop than the VWR springs. Any insight about adjustment prior to install would be greatly appreciated? I would love to hit close to the correct height the first time as if I am understanding the adjustment procedure, I need to pull the wheels again to make any supplemental adjustments, right?
Which direction do I turn the adjustment "collar" to bring the car down? And do you just measure the exposed threads or count the threads from the top down to the collar to get both sides adjusted the same?
Any insight on that part is greatly appreciated! Thanks in advance.
Ben
Ben
