We carry a variety of M7x32 replacement assembly bolts for 3-piece wheels and select 2-piece BBS, OZ, RH and Artec 3-piece wheels.
These M7x32 bolts may fit other wheels as well, but please check the specs of your existing assembly bolts against the measurements shown below.
Our M7x32 bolts are confirmed to fit these wheels:
- BBS RS & RF
- OZ Futura, Mito, Pegasus, Fittipaldi & AMG
- RH ZW1, ZW2, P-RAD, ZW3 & ZW4
- ARTEC Edition L
BFI/ARP M7x32 ASSEMBLY BOLT (STAINLESS STEEL)
BOLT SPECS:
- M7x1 shank diameter/thread pitch
- 32mm shaft length
- 24mm thread length
- 8mm, 12-point bolt head
- 6.8mm head height
- 13mm flange diameter
- 450 Stainless Steel
- 170,000psi tensile strength (≥12.9 grade bolt)
- Torque spec: 19N*m or 168in/lbs using ARP Ultra-Torque assembly lubricant
- Available exclusively through Black Forest Industries
BFI M7x32 ASSEMBLY BOLT (GOLD / Ti-N PLATED)
BOLT SPECS:
- 32mm shaft length
- 24.5mm thread length
- 7mm head height
- 10.9 high tensile strength
- Ti-N plated steel bolts
- Torque spec: 25N*m or 222in/lbs using Loctite 243 Threadlocker
BFI M7x32 ASSEMBLY BOLT (CHROME PLATED)
BOLT SPECS:
- 32mm shaft length
- 7mm head height
- Chrome plated steel bolt
