BFI - Heavy Weight Shift Knob
Status
Not open for further replies.
black forest ind
Cary, North Carolina
Ride
All of them
Hey BFI! I bought and installed your Air Leather GS2 and think it is excellent. I was apprehensive on the way it installed to the shifter with the screws, but I have confidence that even without the locktight it is well made and will stay tight. I love the quality of materials and the feel of the shifter, as well as how much lower it is than stock. It is an excellent upgrade.
The only less positive feedback I have is that even though the adapter base is tight and the knob is fully tightened down and does not spin, it would still clunk when changing gears if the shift was anything except extremely gentle. I removed the knob and wrapped the shaft in several layers of electrical tape so that it was very snug and there is no more clunking of the shaft hitting the inside of the knob when shifting. Although no one will ever see this, I know it's there and that is not how I like to modify my cars. Is there anything in the works or could there be, even for an additional fee, for a small rubber or silicone sleeve or cap to go underneath the shift knob to have it firmly fit for an experience on par with an OEM quality product? I will be searching for a solution, but wanted to share my feedback and reach out to see if there was anything you all offered already.
I love the knob and have gotten many compliments on it! Thank you!!
Thanks for the feedback!
The shift rod in the MK7 platform is a stamped steel part, which is not perfectly uniform between each and every vehicle. Due to variance in tolerances between vehicles, creating a "one size fits all" sleeve isn't really possible. We have looked into a few different ways to alleviate that in the small portion of vehicles that have that noise, but adding an insert would also mean that we would need to machine more of the knob during production, meaning it would make the knob lighter.
That being said, we are always striving to produce the best product possible, and if we do come up with a permanent solution in the future, I'll be sure to reach out to you on the forums and let you know! :)
HercAviTech
United States
Any tips on installing one of these and maintaining the neatness of the boot? I have a MK7 GTI and I REALLY want a GS2 Schwarz, but I'm nervous because in most of these pictures the boots don't look as neat anymore. I really want it to retain a look of factory quality once installed.
black forest ind
Ride
All of them
Hot off the production line, we’ve just released 4 new versions of our GS2 Heavyweight Shift Knob. These special edition knobs are wrapped in actual factory Magma Red perforated leather and are available in machined silver, or anodized black for both Manual or DSG / Automatic vehicles. These new knobs are just oozing class and simply melt in the palm of your hand. If you’ve been holding out, then this knob might just be the one for you. The GS2 Heavyweight Shift Knob, better shifting you can feel.
black forest ind
Ride
All of them
At long last, the new Weighted GSB Golf Ball Shift Knob is here! This modern update on a classic design feels significantly more hefty than the original with its steel upper portion and aluminum lower, shifting effort is substantially reduced while feel is greatly improved.
And we don’t use just any leather either. Wrapping the top portion is a semi-analine, uncorrected natural hide; OE Audi “Valcona” leather, soft to the touch but with good wear resistance and durability. Simply put, better shifting you can feel.
black forest ind
Ride
All of them
@ben_innfab got the first VW/Audi fitment GSA knob and anodized it purple to match the build that him and @macxattack are working on! We love seeing all the custom finishes customers get done with their knobs.
black forest ind
Ride
All of them
The New Year is upon us and we want to help you with your resolution to get your project finished in 2017. To make things easier for you we’ve dropped prices on select parts by up to 17% on our webstore. In addition to that we’ve added discounts on some of our other more popular parts lines. So put that holiday money to good use and and pick up some of the parts you didn’t get at an even better price. This will be the last chance to save for quite some time, so don’t miss out!
Blade3562
Middletown, PA
I just bought an installed one of the DSG knobs in my '07 Eos VR absolutely love it! It's awkward to pull up instead of press a button, but I'm adapting! (Ignore the missing airbag in the first pic, it still hasn't arrived from Europe.)
gmi99
Florida
After installing I also had a click / clunk when shifting. Fixed it with a piece of 10mm shrink wrap tubing. Now snug and silent.
Status
