heftysmurf
- S. FL
So I have a base model 2021 GTI S and was wondering what is the best (for a $500 budget) to get better sound.....Helix kit or replacing the speakers?
So would you say that the factory headunit has enough juice to support better speakers?I replaced the speakers and tweeters prior to installing the Helix. I went with JBL stadium setup, it made a huge improvement over factory.
Depends on your budget and needs. Speakers and tweeters make a great improvement and are easy to DIY. The helix adds some sorely needed bass (at least if you listen to that kind of music) I started off with just speakers but the increased mids and highs really brought out the lack of bass for me. The combination of speakers/tweeters/helix has me at 85% satisfaction. I wish there was a tiny bit more bass but honestly it's more than sufficient for what it is. especially when you consider the entire setup cost me less than $1000 which is pretty damn cheap all things considered.So would you say that the factory headunit has enough juice to support better speakers?
So which would you do either or?
So it says that it "Does not fit my 2021".....is it the programming?If you do pick up a helix new, shop around online as some dealers offer pretty decent discounts. Looks like VW of Murrieta where I picked mine up has them for 25% off currently:
https://parts.vwofmurrieta.com/p/Vo...-Subwoofer--Soundbox/70346182/000051419B.html
VW also offers rebates, looks like it's currently 15% cash back on a prepaid card on accessories until the 30th.
https://www.volkswagenrebates.com/
Someone else with a 21 S has done the install, quick skim it looks like the only difference is the connections are behind the touch screen and not in the glove box:So it says that it "Does not fit my 2021".....is it the programming?
Physically I know it fits.
If anyone knows how you can start off with an idea for a budget for mods and then wildly exceed that it would be you.
Did you upgrade the subs in the helix?I think it depends if you're going to stay at that $500 limit or build on that. If it's the only $500 you plan to spend on the sound system, i couldn't be happier. If you plan to build on the system, that Helix amplifier is the jewel of that setup. The actual sub is sub par.
https://www.golfmk7.com/forums/inde...system-with-jl-c1-650-and-jbl-gto-629.374814/
