TCdaosithui
- SoCal
where can I buy DG springs?
will I need alignment afterward?
So, I have looked through the entire thread, along with a number of others on the topic. I just wanted to solicit the opinions of random internet strangers/friends. My main goal is to reduce the wheel gap on my DD ‘17 GTI S about 3/4”, keeping stock wheels/tires (I will upgrade them early next year to Michelin PS A/S 3+). I can’t go too low because of bad roads and while I would like a little performance upgrade, I don’t want to give up much for ride quality (again, because of the aforementioned terrible roads). Seems like DG is the best bet. I had originally considered the H&R OE (seem to be ok) and the APR Roll-Control Springs (but, they seem to drop more like 1”+). Any suggestions otherwise? Thanks!
Again, be careful when 034 says they're designed to work with DCC. I'd be skeptical about a progressive spring with higher rates playing well with all of the DCC modes well. I haven't had it so it's all conjecture. Based on wanting a mild drop without a big increase over the stock rates I'd push you in the direction of DG's. You may be thinking they aren't enough, but i they are heavily influenced by the dampers, and would seemingly fit your needs quite well.After reading up on all the different springs available, I think I’ve narrowed down my list. My gf and I just picked up a 19’ GTI SE 6MT(w/Experience Package) so it does have DCC. I do plan to keep the stock dampers for now, and I’m not too worried about the long term effects since we won’t be putting a ton of miles on it. Mainly looking for a mild drop (around an inch) and a slight improvement in handling. I don’t want too high of an increase over the stock spring rates.
I think what I’m more worried about is the drop visually. I noticed a lot of the springs lower the front a little more and it appears to be raked (since the front arches are taller than the rear). With that being said I’d much rather have an even body drop, even if that’s means the front appears to be higher (or reverse raked as some people call it.
So far at the top of my list are the 034Motorsport Dynamic+ Springs. I like the slight increase in the spring rates, they do state that they’re designed to work with DCC, and the body drop looks even. I noticed they’re also one of the most expensive spring options available( but they’re currently 20% off on their site for Black Friday). I’d say second on my list would be ED Emmotion springs (but In the pics the cars looked raked). Or do some cars appear to be raked cause they’re DSG?
I’m super new to VWs so I’m trying to read every post I can related to he springs that I’m interested in. Sorry for the long post.
Yeah, you can adjust a bit for reverse rake, but can't really do anything for positive rake without getting even more creative.As mentioned in first post, H&R OE Sport real world drop is lower in the rear and will give you that flat look. I have linear Eibach, not a fan of the raked look either and would go with the OE Sport if I were doing it over.
uberdot has it: https://www.golfmk7.com/forums/inde...about-new-shocks-struts-and-body-roll.369579/Is anyone running H&R Sport Springs with Bilstein B8's?
I haven't found much info on this setup. I bought the springs a while ago and never installed as i considered coilovers but I think the H&R/Bilstein mix will be a better combo. Any thoughts?
Tons of good info in this thread! I'm about ready to upgrade my struts and wanted to see exactly what should be replaced while I'm in there. I've been on Eibach Sportlines for about 40k miles, so a pretty significant drop on the factory struts. I was going back and forth between the B8's and the Koni's but it seems like Koni is ultimately the better option. Car is never tracked so I want something comfortable.
Besides picking up a set of struts, what else should be replacement within the suspension? Upper mounts and bearings? Anything else?
