Great discussions in here. Here's what I'm thinking for my DD setup that I occasionally toss into autocross:
- OEM springs. I think the ride height and general stiffness is appropriate
I would run 400in/lb rear with the OEM front springs. That is my non-race setup. It feels fantastic.
- Koni Special Active dampers. A bit softer where I want it (small bumpy stuff) and a bit firmer where I want it (cornering, maneuvering)
I would run the Koni Yellow, and deal with the difficulty of adjustment, but once you get it right, you are done adjusting.
I would look into the 034 fixed strut mounts, they give -1.5. More is better.
- Rear sway bar and rear bracing. Already done. Great upgrades that made the car more responsive and easier to rotate in tight autox elements.
Not a fan of bracing, but I know it's cheap.
I'd look into a front bar, too. You are already in STH with the camber mod, so why stop with just a rear bar? Adding just a rear bar is hardely reducing body roll since the stock Front roll couple % is rather high, like 70%, which means most of the roll is happening at the front. All you've done is locked the rear tires together more and you unload the inside tire earlier (off the ground). It may feel fast, but there are better ways.
In my view, this setup would address a few key goals of mine:
- Smooth out and add composure to the stock jittery ride. Stock suspension feels quite unsettled over rough stuff, especially at 65k miles. Around town, it doesn't always feel like a quality vehicle.
- Reduce body roll. SA's stiffen up a decent amount in cornering, from what I've read.
The special actives don't "stiffen up". The name is misleading, it just has a bump blow-off feature in the high-speed shock shaft range. In lower speed shaft movements, there is some amount of stiffness in rebound, probably less in bump, like the Koni yellow.
- Add some much-needed front camber to aid with turn-in and reduce some understeer.
- Big key: None of these things take the car too far in any direction or drastically change the nature of the car I love. This car is my daily, first and foremost. I just want to tweak it to make it better.
My full tilt STH build is not a dramatic change from stock, just a little stiffer, with a specific alignment, and better equipment.
Notes:
- I'm unsure how Koni SA's perform when you hit bumps while cornering hard. They can't be both stiff and soft at the same time, so which takes over in that instance? Also, how does less rebound damping actually help the ride -- isn't poor rebound damping what the OEM dampers suffer from?
High shaft speed blow-off, like I mentioned above. A shock does not see corners, only shaft speed. So the body leans, the shock dampens the initial movement, then all things being equal, nothing is happening in the shock during the smooth corner. When a bump is hit, the shock shaft moves up in compression, and if the shock shaft speed meets a speed threshold, separate oil passages open up to allow the oil to be displaced without going through the normal valving route. Then the suspension rebounds via the potential energy stored up in the springs. The shock is now moving in extension or rebound. Some amount of rebound damping is happening in the shock to smooth out the extension so the car does not bounce back and forth.
Poor rebound damping can be not enough at high shock shaft speeds after a bump is hit, and the rear of the car bounces more than 1.5 times per bump. Your rear passengers will hate you. Or too much rebound and the car is skittish and skates over bumps, not giving the tire time to stay in contact with the ground.
I found the OEM rear shocks to lack enough rebound, and the springs were too weak, causing way too much rear bouncyness.
- I considered Bilstein B6's. I haven't totally ruled them out because the Bilstein quality is unbeatable. But, I would lose the softer damping from the SA's and easing the ride is a key goal for me.
- I considered Koni Sports, but even though they're adjustable, they have to be practically uninstalled to be adjusted. In my view, that makes the adjustability pretty pointless for my needs. (Ideally I could adjust them soft for daily'ing, and firmer at the track).
You need one setting for a given sprung weight, which won't change too much unless you constantly have a changing passenger load. If it's just you, set it and forget it.
I think there is a way to modify the fender liner to gain access to the rear adjuster.
- I recognize my tires may be contributing to some of the poor ride quality I'm experiencing. But it's hard to parse out how much if that is the tires and how much of that is worn stock suspension. But by most accounts, the stock suspension isn't up to the task, regardless of tires.
It's almost entirely the rear shocks and springs.
- I considered downsizing to 17's.
- I think 18's look better on these cars at stock ride height.
- That might help soften some impacts from bumps, but wouldn't necessarily solve the jittery, unsettled nature of the stock dampers.
True.
- Right now, since I'm just a casual autocrosser, I'm using the same wheels and tires for both daily and track. Street tires with a taller sidewall = flimsy rubbery roll on the courses with no feel
I don't think your assessment of 17 vs 18-inch tires is correct.
In fact, I'm moving to a 17-inch tire after my current tires wear out.
I'm curious if anyone feels differently or strongly on any of the above, or if I have any bad info. Thank
I guess I feel differently
