thanks. and sounds like you take your car to the track with some hard braking and no issues?
also curious if you turned XDS off completely or played with any of the electronic nannies?
also did you leave the rear dust shields on or take those off?
also what pads are you running on the front with your Brembo kit? right now I'm thinking pagid RSL29 endurance pad for track and some stoptech posiquiet pads for street use since i've heard their sport pads that come with the bbk kit can create deposit issues on the street
I turn off XDS (that's the braking effect to reduce wheel spin?) because it interferes with the Wavetrac. The other nannies seem to be track dependent. At Summit Point Main, I can leave them on without any ill effect. On Shendandoah or NJMP, they really interfere so I turn them off there. Not sure why it seems to be track dependent.
I have left the rear dust shields on. And although someone made a generalization that EBC Yellow are bad, they are fine for the rear. I wouldn't use EBC on the fronts. Been there, done that. No bueno. Stock pads on the rear are also ok.
I use Hawk DTC-60 on front. I get two track days out of them. I guess I use the brakes too much! I tried Pagid, but at nearly twice the price, they didn't last twice as long. I have slotted disks on front, which probably doesn't help. I can't find plain disks for the Brembos. I also have removed the dust shields and have installed the RS ducts. I haven't had any brake issues with this set up.
