@mawallace: Hi - you must have an older version mk7 because VW stopped including "SOC" in later model cars
My other guess (it's an observation, really) about your car is that it has what VW call "Recouperation" - or regenerative braking which turns your car's kinetic energy into electricity to charge its battery and boost efficiency.
If you think about Recouperation in terms of SOC, you will conclude that it's never possible for the car's alternator to be allowed to fully charge the battery to 100% SOC - because the car's Energy Management System (EMS) must always isolate a percentage of the battery's rated capacity as headroom to receive the regenerated energy.
So the SOC reading on a Golf mk7 (on models that permit the reading) is seldom if ever 100% and the reading 80% (which is normal even for a brand new battery) simply means that the alternator has successfully completed its job. The remaining 20% is the proportion of the battery's rated capacity that has been allocated to receiving generated energy from Recouperation.
I had an early mk7 with SOC facility from new for many years and the reading was rarely higher than 80% - regardless of battery replacement
As I have said, later model mk7s no longer permitted SOC readings - I suspect this happened because VW received too many questions like yours - no offense intended!!
Don
