gixxerfool
- New Jersey
- 2016 Golf R
Check the pins that affix the door card to the door. They should have seals on them so when the card is placed on the door it’s sealed and the water should be directed down the door through the drain holes.Thank you. Just to follow up I replaced the carpet and insulation. It wasn’t actually THAT difficult. Should have done it first.
But I am noticing water on the door sills after heavy rain. So I removed the door card and had a friend spray the hose at the window for 2 minutes and then water started dribbling through the hole that I have circled. My question is - can I seal thay hole up? There was no water coming from around the speaker now.
