TVbuster
- new england
Hey everyone, I could use some help. I'm not sure if this is the best section for this post but my 2017 GTI has developed a bad mildew smell over the past 2 months. I didn't know what it was for a while but now it's noticeable. Even if I leave a bag or something in my car overnight, bring it inside, the bag will smell like mildew.
I did some research and found that some people say the AC drain hose is "loose" from the factory and allows water to leak. I do use my A/C frequently, even in the winter, to help defrost the car. So I removed the carpet and checked the foam. The foam area near the A/C drain hose did seem to smell and it seemed to be the strongest source I could smell. And I noticed there was a darker yellow line as if some water had been leaking but it was only slightly damp. I ran the AC for 10 minutes with a paper towel placed in this area and it did not have a drop of water on it. But you can see the yellow area in the pictures and it's above the drain so maybe it's leaking higher up. But I thought the paper towel test would be a good one.
I put some bleach/water mix on that area to try to clean it and remove the smell and I have not been using my A/C for about a week. It seems like it's gotten slightly better but it's hard to say. It could be my nose playing tricks on me. But I also replaced my cabin air filter for the first time in 3 years (i know, bad) and first time in 50,000 miles. The old one had some leaves on it but didn't smell like mildew.
I also bought klima klean and I'm gonna spray it in there soon.
Does anyone have any thoughts based on my pictures where this leak could be coming from?
