Pbrowne
- Clarke County, Virginia, USA
- 2021 GTI
So I finally have successfully enabled rain closing in my 2015 Golf SE w/lighting. Mine has the RLS sensor.
Here are the steps that I took:
1. Hook up the VCDS cable and open the VCDS application on your laptop. Then turn on the ignition, but do not start the engine.
2. Go into [09] Central Electronics
3. Go into Security Access and enter 31347
4. Go to Adaptation and change the following:
5. Go back and into Coding in [09] Central Electronics and selected from the pulldown to select “RLS.” I used the Long Coding Helper to check the following boxes:
6. Go to the Infotainment screen in the car to go to Car then Setup then “Factory Settings,” then “Reset Mirror and Wiper Settings.” Go back to “Car” and “Settings: and check “Automatic Closing in Rain” if it is not already checked. Check that the “Rear Wiper in Reverse” box is also checked. Make sure that the “Convenience Close” has been selected, not inactive.
7. After that, make sure the wiper stalk is up one from the bottom position to the intermittent position.
8. Bes sure doors are closed. Open window(s) and/or sunroof. Turn off the ignition and remove the key/fob. Lock the doors with remote fob.
9. After a few minutes spray water on the windshield over the sensor and the windows should close
Some observations:
• If I unchecked the “Rear Wiper in Reverse’ box, the windows would only close once but not again unless I did another factory reset.
• If you unlock a door, you must turn on/off the ignition before relocking doors.
• Following the above instructions, the Automatic Rain Close worked after a few minutes, after an hour, and after 8 hours.
• (15) Access Control 2 - Regenschliessen_ein aus (Rain Closing on / off) - Select Active
• (16) Access Control 2 - Regenschliessen_art (Rain closing Type) set to Permanen
• (28) Access Control 2 - Menuesteuerung Regenschliessen (Menu Control Rain close) – Set to Active (enables the menu in the Infotainment screen)
• Byte 0 bit 1: Rain/Light sensor active
• Byte 0 bit 2: Rain closing active
• This sets coding from 00A8DD to 06A8DD. Note that you can also enter the value 06A8DD directly.
Some observations:
