Rmcnelly
- Portsmouth, VA
- 2017 Golf Alltrack S
I tried some real low tire psi, like near 32 in the front on RE71R’s and damn near scrubbed the lettering off the sidewall it rolled over so much.Thanks folks! The driver of the Golf R had a lot of Autocross experience, but not in a front/AWD car (the owner of the Golf R wanted them to drive it and see what they could do).
here was their best run. I’ve learned a lot by looking at their throttle input.
The 255 660 is a very wide tire, wider than the outgoing 265 RE71r, on a 9-inch wheel. I would not go any larger than 245, if it's available in the correct ratio.Also wondering if I can squeeze 255/35 RT660's onto these 18x8" ET45 wheels with the amount of camber I have (-3F, -2.3R). Tires in the photo are 235/40-18 RT660.
Lots of folks running wider tires than recommended wheels, I'm more concerned with tire clearance.
I don't see 30/32 as the recommended pressure.I’ve been trying lower pressure on my favorite on/off ramps and the car felt good at 31f/32.5r.
Maybe I was just over driving the car when I first got the RT660’s, and not having adjusted from the MX-5.
I’ll try starting at the recommended 30f/32r next Sunday, and will keep my tire pump in Grid in case I don’t like it
Is there a difference for those of us running stock wheels and high-performance street tires (Michelin PS 4S) versus those running 17" wheels and more track-focused tires (RE-71R's, etc)? That is, I wonder if the stiffer sidewalls on the track-day tires work better with lower tire pressures than the street tires? I've heard the RE-71R tires ride hard (and are noisy), the newer RT660s and A052s are not a whole lot better.
On a related note for dual-mode (street and autocross) setups, how far from the standard recommended toe-in settings can you go before you start seeing negative after-effects on the street? Do you lose straight-line tracking, or higher tire wear, or what? My last GTI was within factory specs, I have not had the alignment checked on my current car (the local autocross site got repaved and they have not allowed us back this year...yet?)
The more grip the more tire pressure, in general.I noticed on concrete i needed more pressure. So instead of 33F, ran 35F and 40R.
On asphalt, 33F is fine for my car and my suspension setup. There are so many variables to this though.
F 2.4 camber, 0 toe
R 1.6 camber, 0 toe
RE71R 255/40R17
