So far this season I haven't needed to spray the rears hardly at all. During this event there was a long delay between runs, and the fronts started to cool down so I tried not spraying, which was a mistake and they got greasy. We'll see how I do tomorrow.
It was caused by 32 psi.That event also resulted in this on the right front tire. The tires didn't show signs of rubbing in two prior events. Both left and right fender screws were polished, so I did the fender screw mod today. The scoring on the tire seems too far inboard to be caused by the fender screw, so I don't know what caused this.
what size wheel and tire? that's a good amount of camber and pressure, surprised it takes that much to not get rollover-3.3 front camber, 400 pound springs, 28mm front sway, I still need 41psi start pressure with RT660's to not roll over. Anyone doing it with less air pressure has some very stiff springs or drives slow.
18s 8 inch wide rim, rt660 235/40…8.5 wide rims would help some, but I do rub slightly on inside if turned to max. I could do with smig less camber. I push the car HARD, send it and my local corse is a fast old runway. Not a parking lot club. I race the 23rd of July, will post a video.
You should have seen the Yokohama’s a052 I ran, chewed crap out those sidewalls!
I also pushed my car hard. That wear looks reasonable, I don't see anything off with that. I do not believe less camber is the answer here, especially on these cars. Also surprised you're rubbing with only 235s in the front. An 8.5" wide rim would definitely help, but those don't look chewed up to me.There ya go. 7 days Autocross. Flipped on rim after 4. Maybe 8 events…I lost count.
It is.That looks like pressure is too high.
GRM has done some fantastic testing over the years. For autocross, to get maximum grip, you'll want it a little lower than that.How so?
You see that Triangle marker? Not supposed to get wear past that. If I use less air pressure it get further into it and Beyond.
This conversation is getting kinda old. You do you boo. I’m happy with my results.
You know more then the tire manufacture? I removed my posts because my car is much different and tire pressure can vary a lot depending on set up. I read dam near ALL of your old posts. Your not as knowledgeable as you claim. In fact I'm done with this forum because its a fan boy club of fools like you.GRM has done some fantastic testing over the years. For autocross, to get maximum grip, you'll want it a little lower than that.
And you sound like an asshole getting defensive when people try to give you information. I've been autocrossing for 35 years, you have too much pressure for autocross, about right for tracking, but you aren't even to the tip of the pointer.
So either maybe listen to people that have been doing this for a long time or don't ask questions if you know you already have the answer you want from your vast experience.
You know more then the tire manufacture? I removed my posts because my car is much different and tire pressure can vary a lot depending on set up. I read dam near ALL of your old posts. Your not as knowledgeable as you claim. In fact I'm done with this forum because its a fan boy club of fools like you. And keep laughing dude, your set up is shit!
Oh no, don't leave...You know more then the tire manufacture? I removed my posts because my car is much different and tire pressure can vary a lot depending on set up. I read dam near ALL of your old posts. Your not as knowledgeable as you claim. In fact I'm done with this forum because its a fan boy club of fools like you.
You are a forum fool. Who cares who you listen too. Your set up is TRASH! It's obvious reading your trash posts. 50 years old with 35 years! ROFL! I WOULD WIPE THE FLOOR WITH YOU!You can't even figure out how to post an insult correctly.
My setup is fast, so don't really care if you like it or not.
I thought you were leaving?You are a forum fool. Who cares who you listen too. Your set up is TRASH! It's obvious reading your trash posts. 50 years old with 35 years! ROFL! I WOULD WIPE THE FLOOR WITH YOU!
I am. When I’m done mopping the floor with you. 15 years old when you started…35 years of experience and still a fool, 50 years old. Did I miss something?I thought you were leaving?
I started when I was 15, my parents both autocrossed and road raced. Are you unable to do simple math?
